and would they scrub with h&r springs?
right...+42mm or better w/ 18 x 7 and aboverichard said:wats up i have 5-zigen mo-5 in hyper black 18x7.5 the offset i have is +43 and the tires are 18/40/225 and i dont scrape
thanks
richard
I'm also looking at 18x8...how necissary is the camber kit to having no rubbing?Fut said:18X8.5 +48 offset w/camber kit, no rubbing!!!
One...
Fut![]()
It became necessary for me because the camber was off when I lowered the car. Plus the camber kit makes sense if you to get maximum wear from expen$ive azz tires!!!jason520 said:
Koni shocks, Eibach springs, 225/40/18'seurovargas said:Whats your suspension setup? and what size tires do you use?
