1 - 20 of 21 Posts
Dont Catch
are you sure its your throttle body? unless your plate or throttle reel is physically broken... the throttle body isnt the reason for erratic idle.
if it revs up and down when its cold for a good 2 mins or so... then you should bleed your cooling system out... also check the FITV on the back of the intake manifold... and also clean out your IACV
Discussion Starter · #18 ·
THANKS YOU'VE BEEN GREAT HELP . BUT............IS THERE ANY WAY YOU CAN CIRCLE THE CORRECT PART . I'M NOT TO MECANICALLY INCLINE . IF NOT I GUESS I FIGURE IT OUT . OR FIND SOMEONE ELSE THATS AS HELPFUL AS YOU . THANKS AGAIN
1 - 20 of 21 Posts
