I'M LOOKING FOR A TPS .IF ANYBODY HAS INE PLEASE LET ME KNOW . TACH NEEDLE BOUNCING TO MUCH DURING IDLE
YEAH THE CHECK ENGINE LIGHT DOES COME ON .are you sure that its your tps sensor? does the check engine light come for? if the check engine light is not on then i dont think you need a tps sensor but if you do this part can be found a lot of hondas. On my old coupe i used one from a 94 honda civic and only cost me 10 bucks. its a little tricky to install because you have to drill out the screw. i hope this helps
YEAH THATS THE EASY WAY OUT . THE WAY I WENT , WHOLE THROTTLE BODYlike i said before you can get them off a lot of honda's but if you dont want to drill it out then you would need to buy the throttle body with the tps attached to it
