ignition check engine light problem - The Acura Legend & Acura RL Forum
Old 09-16-02, 03:43 PM   #1 (permalink)
hey do anyone else have problems startin there car? i have had to sit at places for like 10 min tryin to start it. it is sittin in the garage right now becuase it cant start. i dont know whats wrong with it does anyone have an idea of what to fix? when i have the key in the engine light comes on and the battery and oil comes on but usually the engine light dissappers any help please thanks.
wTnLeGeNd is offline   Reply With Quote
Old 09-27-02, 12:41 AM   #2 (permalink)
Car 1: 1991 Legend LS Coupe
I had a similar problem with my 1990 honda accord coupe 2.0Si
in Japan. Find your fuel pump relay/main relay and tap it with your finger with the ignition on. If your ckeck engine light goes out when you do this, then you need to replace it. After tapping it, you should be able to start it. Another test is to listen to your fuel pump when you turn on the ignition. The fuel pump will turn on for a few seconds then turn off. If you do not here this, then it is your fuel pump relay/main relay! Also check your fuel pump fuse.
Make sure your spark plugs is in good condition. Lots of carbon buildup makes the engine hard to start!
DJ'$-Ack is offline   Reply With Quote
Old 09-27-02, 10:25 AM   #3 (permalink)
I betting: Main Relay
Not worth the hassle to troubleshoot, just pull the lower dash and change it.
MC® is offline   Reply With Quote
Old 09-27-02, 10:35 AM   #4 (permalink)
Send a message via AIM to blklegend Send a message via Yahoo to blklegend
Yeah replace the main relay first. Then if that doesn't work troubleshoot because to trouble shoot if it is the main relay is a real hassle. you need a test light and also you need to get to your fuel pump which is a pain.
But it does sound like the main relay.
Main relay isn't expensive nor is it difficult to replace if you are handy with a socket set.
blklegend is offline   Reply With Quote
Old 09-27-02, 03:27 PM   #5 (permalink)
hmmm, when you turn the key, what is the fule pump sounds like? Example please.
CakeDaddy is offline   Reply With Quote
Old 09-27-02, 03:42 PM   #6 (permalink)
502MotorSports.com
502 MotorSports's Avatar
Car 2: e60 530i | e46 330i
Car 3: S430
sounds like this
vvvvverrrrrrrrrooooooooooomm
real low, about 40hz-70hz, 3-5 secs long
502 MotorSports is offline   Reply With Quote
Old 09-27-02, 03:46 PM   #7 (permalink)
YEAH YEAH YEAH, I see. thank you Sir.
