Newb Foglight ? - The Acura Legend & Acura RL Forum
Old 08-22-12, 06:39 PM   #1 (permalink)
Type II Dude's Avatar
Car 1: 1993 Legend LS Coupe Type II
Newb Foglight ?
Yes, I did a search and I did not find all my answers.
1) Is my 93 LS Coupe pre-wired for fogs currently just plates in the lower bumber and no fog switch?
2) I have TCS on my car and the current switch has Dimmer on left small blank then TCS far right. The fog switches I found have a larger fog button. Where will the fog fit? I only have room for a small button where blank is. Do I replace the dimmer area with the fog? If someone has a pic of the proper switch I need to accomodate my setup that would be great. If someone has an extra to sell that would be great too
Type II Dude is offline   Reply With Quote
Old 08-22-12, 07:14 PM   #2 (permalink)
Fut RIP
L3GDKANG/JDMKANG's Avatar
Car 2: 92 Alpha/ AlphaT KA8
Car 3: 91L,93LS,94LS KA7's
iTrader Score: 39 reviews
You will need the switch that has courtesy, tcs, and fog and unless removed your car is per wired for fogs
Originally Posted by Blackend
Old 08-22-12, 11:39 PM   #3 (permalink)
Ok does anyone have a part # for this switch? Also can someone post a pic of it. Do you know if the courtesy or Fog button is reduced in size? One would have to be to occupy the space provided.Well I am looking at the switch I have now. Is it possible to dismantle a switch and interchange the inners to create the config I am needing? L3GDKANG/JDMKANG thank you for the input. Checking your posts tells me you are one of the go to guys on this board. Just to confirm I should have a harness complete ready to accept the lights and switch on bth ends?
Old 08-23-12, 02:42 AM   #4 (permalink)
Fut RIP
Yes and the under dash harness its like your switch but has a small fog button. I'm at work but I'll try to post pics for you tomorrow
Old 08-23-12, 09:58 AM   #5 (permalink)
Fut RIP
here you go as promised. the top 1 is the 1 you need and this should be the parts number double check when you order it!
http://i624.photobucket.com/albums/t...2C7A30A19C.jpg
http://i624.photobucket.com/albums/t...2C73E6D45E.jpg
Old 08-23-12, 12:57 PM   #6 (permalink)
Car 1: 92 G2 4D 5spd...
Car 2: 99 Tahoe LS 4wd
Car 3: Trek Bike (Less Gas)
If you have the switch that has the larger button, I might be willing to work something out with you. I currently have a new switch with all 3 buttons, but I need the large button switch.
NYTAHOE is offline   Reply With Quote
Old 08-23-12, 05:35 PM   #7 (permalink)
Fut RIP
Now see that sounds like it will work out for both of yall
Old 08-24-12, 01:38 AM   #8 (permalink)
PM sent to you
Old 08-24-12, 11:31 PM   #9 (permalink)
I have another question. The interior door lights and light under glove box are not on. Light up in headliner works fine. Is there one fuse designated for my issue?
Old 08-24-12, 11:46 PM   #10 (permalink)
Fut RIP
Check bulbs and try courtesy switch. The fues is under the dash.
Old 08-26-12, 01:44 AM   #11 (permalink)
Kang, are you sure fuse under dash. There is one in the engine fuse box labeled interior lights. That was for the overhead light and map lights. Lower fuse box has 2 fuses labeled running lights. What is the fuse in question labeled? All fuses I checked were fine and bulbs appear to be ok as well. BTW it was a bitch removing the light covers on the doors. Switch lights up when you turn the lights on. When you say fuse under dash is there a seperate fuse location for the courtesy lights? Kang I also pulled the switch out t check connections and I did not see the connector for the fog switch. Is that sucker buried in there somewhere?
Old 08-26-12, 01:48 AM   #12 (permalink)
Tahoe, can we do a deal on your switch? I have fogs arriving next week and I would like to complete the project all at once. I can buy it from you. Let me know either way so I can continue my search.
Old 08-26-12, 12:50 PM   #13 (permalink)
Fut RIP
The fuse will be under the hood for interior lights I've never had any problems with dash lights so I though it was under the dash. The fog switch has the connector but the fogs come with the under dash harness if not then it has to be made.
Old 08-27-12, 02:44 PM   #14 (permalink)
I apologize for not getting back here sooner, I had CPU issues for a few days. I have a meeting @ 3pm today and will get back to you around 6pm. I will send you a photo of the switch and instructions that came with it.
Old 08-27-12, 10:13 PM   #15 (permalink)
Tahoe are your fingers broken...dial my #
[IMG] code is Off
