-   DIYs (https://www.acura-legend.com/vbulletin/forumdisplay.php?f=13)
-   -   Accessory Installation Instruction Sheets (https://www.acura-legend.com/vbulletin/showthread.php?t=120509)
stevieray 04-03-08 09:52 AM
Since there seems to be a blue million sets of the various Accessory Installation Instruction Sheets floating around, we thought it would be a good idea to have a central location for as many of them as we could gather up. In addition, if anyone else has managed to get a set of these and wants to share, PM me or whats77inaname (Michael) and we'll shoot you our fax #. Big ups to Michael for agreeing to put them in .pdf format and hosting:
'94-95 2-Dr Coupe Foglights
stevieray 09-22-08 12:14 PM
daveCFPrez 09-23-08 12:42 AM
nvrmind
Homeboyx 05-24-09 12:09 AM
any1 have the engine wiring diagram???
stevieray 05-26-09 06:11 AM
Ummm, you need a HELM manual for that. Go to www.helminc.com and get one. Best $80 you'll ever spend on your Legend.
Blood Riot 05-26-09 10:13 AM
You wouldn't have the wiring diagram for radio/cd player install would you Mr. Stevieray?
stevieray 05-26-09 10:23 AM
As in the color codes for the stereo harness? If you're going with an aftermarket HU, Scosche makes an adapter harness/pigtail for Honda/Acura that plugs into the factory harness and allows you to wire the HU harness right in.
Blood Riot 05-27-09 09:10 AM
The reason I ask is because the Legend that I have for my sister was trash when I first started on it. I think I may just run my own wires, the OEM wires are all mixed up and messed up too.
stevieray 05-27-09 03:39 PM
Eliot, if the OEM harness is FUBAR, I'd do just that. Definitely the speaker wires and just reuse the 12V power lead.
AKing 06-29-09 12:56 AM
Thinking about some Hella optilux 2500 foglights on my 95 L Sedan, but it doesn't look like I have enough room on that black plastic bottom grille. Do I have to mod it for fog lights?
C and P 07-03-09 03:37 PM
THANK YOU!!!! I bought a kit and had two single BRN leads that were not depicted in the I did the best I could with the manual I got from HELM--Acura Legend Electrical Troubleshooting 1995 from American Honda Motor Co. Inc. as it has a wiring schematic and photos of the major harnesses but not all points are depected. I have two posts that I can't figure out where they go, each with a single wire and each with a single PIN BROWN harness plug-one is a blue wire with a red stripe <looks to be the one that is noted as C-192 (1-BRN) 'option' on page 201-8 of the Acura Legend Electrical Troubleshooting 1995 from American Honda Motor Co. Inc. Picture 54 'Left Kick Panel' , the arrow points to a master wire loom (14 PIN) with BLACK tape-not Blue as for accessories> the other is a white wire (labeled with a Sharpie '5'-I guess from Acura as the Fog Light Kit was Factory Sealed. Thank you...I was trying to have the entire car redone before I posted pics and updated the profile, but I guess that is why we are all here to help each other!!! Weir Canyon Acura can get you pre programmed Acura Factory remotes that work, I know-I did it they are great. Mike and Danny are very helpful tell them Craig sent you!!! [email protected]
coyote3500 08-15-10 02:43 PM
Have a 93 Legend Sdn that I've installed a Avatal Remote start/ignition kill in since my factory remotes are dead. Problem I'm having is finding the right wires for the Avatal to tap into for the disable/enable of the factory system. Anyone with ideas? Would be great.
Also, I'm looking for a front gold grille & emblem if anyone has anything. Thanks
janamarie 02-02-11 08:16 PM
Originally Posted by stevieray (Post 1341845)
Here's some more:
This is great. I can compile all of this. thanks.
milobmx 02-22-11 06:05 PM
Any one have or know where to get the instructions for 91-93 Coupe Fog Lights?
L3GDKANG/JDMKANG 09-26-12 08:14 PM
