DIY:caliper conversion(type1-->type2) - The Acura Legend & Acura RL Forum
Old 03-01-05, 07:48 AM   #1 (permalink)
swift's Avatar
Car 1: 92' C35 KA8 5spd
Car 2: 92' Ka8 5spd turbo
Post DIY:caliper conversion(type1-->type2)
This is a DIY to replace front calipers on type1 coupe to type 2 calipers, on type1 brembos......
tools: metric sockets(14mm,17mm,19mm???)
breaker bar
PB blaster(wd40)
10mm wrench/brake line wrench PLUS: easier with air tools
brake fluid
brake pads
brake cleaner
4hr estimated time??
*loosen lug nuts on front right, place jack and jack up and put stationary jack support under,--place ebrake first, place further weight behind rear tires to be extra safe...., do same to left side.
*take wheels off now
*spray bolts with pb blaster and let sit for 5-10min
*loosen brake line screw and other two bolts(you may need to turn steering to get at them)
* place bucket underneath and remove brake line screw, tie up with some wire to slow fluid drainage
* take out both bolts on caliper and tap caliper with rubber mallet to get off rotor
--do reverse with torgue specs but with type2 calipers
pics included VVVVVV in order
Old 03-01-05, 07:52 AM   #2 (permalink)
swift's Avatar
continued
further pics in order:
Old 03-01-05, 07:55 AM   #3 (permalink)
swift's Avatar
and some more!!
I love pics!!
BLEED brakes by have someone press brake while your outside, and go from side to side at least 4 times....or more.may take a while
and now my car with my new calipers and NGK plugs ready for test drive!
Old 03-01-05, 08:03 AM   #4 (permalink)
swift's Avatar
mmm
sorry for so many pics...
lettering got shrunk because of pics being resized
LABELED THE BRAKE SCREW THE BLEEDER SCREW IN ONE PIC....SORRY!!!!!
Hope this helps with brake jobs and dispelling rumors of brake performance...they work great and aren't broken in all the way yet and i still have some air in system..
-swift/ben
PS- any further comments or specs would be appreciated as i am being rushed to get to work.
215whp+
Old 09-23-05, 10:46 PM   #5 (permalink)
HARLEMLEGENDZ's Avatar
Car 1: 92 WHITE COUPE(mine)
Car 2: 92 pearl white coupe
Car 3: and 15 more coupes
Send a message via AIM to HARLEMLEGENDZ Send a message via Yahoo to HARLEMLEGENDZ
wat are all differences in type1 coupes and type 2 coupes
This $hit Started In Harlem
HARLEMLEGENDZ is offline   Reply With Quote
Old 10-06-05, 08:01 PM   #6 (permalink)
misdeismo's Avatar
i thought type 2 calipers didnt fit behind the 15" oem wheels.
misdeismo is offline   Reply With Quote
Old 12-05-05, 04:10 PM   #7 (permalink)
what!
kotetu's Avatar
Car 1: 95 LS Coupe 6 spd
Car 2: 02 TT225 Quattro 6sp
Car 3: 94 L Cpe 6spd - sold
iTrader Score: 20 reviews
hmm.. I did the twin piston brake caliper swap on my Prelude using the Legend's 28 mm rotors. It was pretty easy. Does the 94 L Coupe (Type2) come with the twins? The wheels sure look like 15's to me.
kotetu is offline   Reply With Quote
Old 12-05-05, 06:42 PM   #8 (permalink)
They do. I have NSX calipers under my 15 inchers.
Herb is offline   Reply With Quote
