DIY Door Handle Removal - Be warned, Not for 91LSMAN (dirty car in pictures!!!) - The Acura Legend & Acura RL Forum
Ľ Auto Insurance
Ľ Wheel & Tire Center
Old 10-30-05, 09:04 PM   #1 (permalink)
Looking for Blk/Bk GS6MT
mondonalds's Avatar
Car 1: 1999 TL - Blk/Blk
Send a message via AIM to mondonalds
I tried to post this in the DIY section, but I dont have sufficient privileges:
Removing the rear door handles:
Step 1: Remove the plastic around the door. Then remove the bolt circled (I believe itís a 10mm) It is not a must to remove this bolt, but it hold the window channel in place and taking it out only gives you more room.
Step 2: Remove this screw.
Step 3: Pull back the maintenance pad.
Step 4: Remove the screw in this hole. It is a 7mm. I found that the Phillips head doesnít work very well.
Step 5: Pull the door handle outward.
Step 6: Pull back the plastic piece. Unscrew this bolt. Although in the following pictures it is fully unscrewed, you do not need to. As long as it is loosened you are fine.
Step 7: The screw you removed in step 4 is holding this insert in place. I put the screw back into the threads so I didnít loose it. You need to push this insert out of the grove it is in (see step 8)
Step 8: Notice the large space on the left. This is where the insert was. With that out of the way, pull the handle outward and then pull it toward the rear of the car.
Step 9: The end closer to the rear will come out first. Keep pulling and the front will come out.
Step 11: Remove the spacer clip for the front portion of the handle. I just put a flat head screw driver in each of the places marked with an arrow. Also, youíre your other hand, hold the part in place, it will go flying if you donít.
Step 12: With the handle off, I replaced the screws. It seems it will be easier to reinstall with these screws in place
Step 13: Now you can remove the inner pieces. I did not take pictures of this, but you will just need to push the part toward the front of the car, and remove the latch, which is circled. It is just press fit, so a flat head screw driver and some leverage will pop it loose (I did do this on my driver door). Once this is done, you can remove the lock cylinders on the front doors. It requires removing the gold colored retaining piece.
Front door:
Pretty much the same, except it is much harder to get the initial bolt out. I just used a 7mm flat wrench, as the window channel is blocking it. Here is a picture of the front insert:
1999 3.2TL - Black w/ Type A (01-07 - ____)
1996 Toyota 4Runner Limited (05-06 - _____)
1993 LS Sedan - Geneva Green Pearl w/ Type F (11/04 - 07/06)
mondonalds is offline   Reply With Quote
Old 10-30-05, 09:10 PM   #2 (permalink)
Type I King
Car 1: 92 LS Sedan
Car 2: 91 LS Coupe 5 spd
Car 3: 95 LS 6 spd coupe
iTrader Score: 7 reviews
good work man
Old 10-30-05, 10:31 PM   #3 (permalink)
I worship the ground you walk on
You just saved me SOOO much time. Thanks!
Old 10-30-05, 10:33 PM   #4 (permalink)
Must the window motors be removed?
EDIT: nmv. you don't have to.
Old 10-30-05, 10:46 PM   #5 (permalink)
I like shiny
Breakout Champion
91LSMAN's Avatar
Car 1: 91 LS Coupe (GONE)
Car 2: Current-02 Corvette
Car 3: 94 LS Coupe (Bro's)
LOL. Nice DIY.
91LSMAN is offline   Reply With Quote
Old 10-31-05, 12:13 AM   #6 (permalink)
SBWooder's Avatar
Car 1: 1991 Frost White LS coupe
Car 2: 1995 Milano LS coupe
Send a message via AIM to SBWooder
great pics, good instructions
I remember doing mine on my coupe after a potential theif gave it a shot to pry my handle off
Chris (Mr. Wood)
Frost on Ivory
SBWooder is offline   Reply With Quote
Old 10-31-05, 01:41 PM   #7 (permalink)
Road Trip King
Tyson's Avatar
Car 1: 1994 LS coupe 6-spd
Car 2: 1994 GS sedan 6-spd
iTrader Score: 19 reviews
Send a message via AIM to Tyson Send a message via MSN to Tyson
Awesome write-up Jason! Can't wait to see the finished product! Post pics when you get her back!
Tyson is offline   Reply With Quote
Old 11-06-05, 01:53 AM   #8 (permalink)
mondonalds's Avatar
Wow, so putting the rear handles back on is much more difficult than taking them off. The hard part is just getting the black spacer to go back.
After a while of trying, here is what I did to get the black spacer back in its place.
1) from the outside of the door, feed a zip tie into the door through the rear door handle hole. You may want to stick a screw driver or something under the handle to prop it open
2) pull the door zip tie through the screw hole on the spacer. Pull the zip tie back out of the door handle hole and use one hand on the inside of the door to help guide the spacer that is attached to the zip tie.
3) Once the spacer is lined up, put your finger on it to hold it in place while you pull the zip tie out.
4) have a 7mm socket handy. put the bolt in the socket and then feed the socket and bolt through the access hole on the inside of door just under the trim
5) guide the bolt to the hole in the black spacer. This part is tricky. Its difficult to hold the spacer and line up the screw at the same time.
6) insert the black metal peice the bolt screws into.
7)tighten down
It took me a few hours to figure this out.
Let me know if either this doesn't make sense or you need additional info -> [email protected]
Old 11-06-05, 12:00 PM   #9 (permalink)
has left the building
iTrader Score: 14 reviews
Nice DIY although you don't have to take the door handles off to take out the lock cylinders. At least I didn't, anyway. Good job---
Old 08-26-06, 06:39 PM   #10 (permalink)
dmjole's Avatar
Car 1: 1987 L Sedan
86-87 Driver's outside door handle replacement
Step by step, here's what I did. If you've got big hands, this is NOT a job you want to try.
First, make sure your window is rolled up.
You might want to put masking tape around your door handle to protect the door paint. Most manuals recommend taking the negative cable off the battery before doing this, but I didn't bother to (since I figured I'd have to be taking it on and off a few times to test things).
Tools needed: rachet, 6" extension (or longer), 10mm socket, needlenose pliers or ViseGrips, screwdrivers for prying, Phillips screwdriver, lubricant for lock (silicon/graphite), maybe electrical grease if you're very fastidious. (If there's a tool to remove the lock cylinder, as indicated down in step 11, that would be VERY useful.)
1) Unscrew all the screws holding the door panel on. This includes the three around the top of the door handle/armrest. It's VERY helpful to try to keep track of which screw goes where, because in an hour you might forget.
2) Pop off the triangular power mirror cover.
3) Before I pulled the door panel off, I lay on the ground looking up at the bottom of the door, and swung the panel out so I could see the wiring connections.
4) Disconnect (and remember which one goes where, which isn't too hard) the following: power window master switch (2 plugs), power trunk, door courtesy light, lock courtesy light (it's at the bottom of the door frame, not the panel--look for it on your new handle to see what it looks like), and door speaker.
5) To remove the panel, push it straight up from the bottom. It might take some taps to get it loose. The panel uses metal clips to fasten to the door frame, right at the inside bottom of the window. Watch out, those clips (and the frame there) are sharp!
6) Peel back the plastic to expose the handle area. Try not to rip it.
--The rods--
7) There are two rods attached to the handle--the door latch rod and the lock rod. The lower rod (lock rod) pops out of the lock cylinder cam. You might need to pry it. Yes, it's a pain. Don't bend the actuator cam. Also, take a look at the cylinder cam. Make a note of what direction it points, because if for some reason you end up taking it off, you will want to put it on the same way. You shouldn't have to actually take the cam off the lock (it uses a C-clip) to get it out of the handle later.
8) The upper rod (latch rod) has a plastic clip that swivels around the end. Note that the latch rod tip is threaded, and has a barrel nut on it that you will be popping out of the handle--you might want to mark the location of that nut, or just be careful not to turn it up or down or lose it. Unclip the plastic clip (push hard), then swing it up out of the way and pop the end of the rod out of the handle.
--the handle--
9) The two bolts that hold the handle to the doorframe are 10mm (like nearly everything else!). Take them off now (a 6 extension is ideal), and be careful not to drop them down the doorframe. Trace the electrical cable (it's the lock courtesy light, apparently) from the handle down to two clips on the door frame, and unclip it from the frame. The lower one is easy, but you might have to mangle the other.
10) work the handle out. You will have to tilt or pivot it. You will have to work the electrical cable on the handle out, also. Before you do, look carefully at its location. It will have to go IN the same place it came OUT--around the window frame, and not binding either of the rods.
--the lock--
11) Now for the lock cylinder--note that the lock cylinder itself is inside a metal tube on the handle that has two holes. You will need to find a way (or get the tool) to depress the clips you can see inside the two holes so you can remove the cylinder. Or, do it the brute way and take a hacksaw to the tube (if your handle is broken, like mine, and will be junked anyway...)
12) Now that the lock cylinder is out, this is an excellent time to lubricate that thing. It's probably a bit corroded, like mine was.
--putting it all back together--
13) Re-assembly time! Slide the lock cylinder into the handle tube--it will only go one way, and one direction, and it will click into the tube.
14) Put the handle back into the door frame. Put the two 10mm bolts in loosely, to hold it in place but give you some wiggle room.
15) Snap the two rods back into place on the handle. You did put the right rod on the right lever, right? Don't bend the handle pieces they snap into. Snap on the plastic latch handle clip. Don't bend the metal lever that the rod pops into, or else the handle will not "catch" on that rod lever, and your door won't open.
16) This is the IDEAL time to test your door. Close it, and open it. Try locking it and unlocking it. If everything works, you're good to go on. Otherwise, you probably bent a rod or a metal piece somewhere.
17) Now to thread the handle electrical cable back down. Don't forget to follow the same path as the cable you removed--go AROUND the window track, and don't wrap it around the rods. It's a VERY tight fit behind the track, unless you loosen the bottom of the window track (another 10mm bolt) to give you some room to work the plug around. Clip it back to the door frame, and plug the connector back in to the door wiring. Don't forget to bolt that window frame back into place.
18) Tighten the 10mm door handle bolts. Check your door again--open, close, unlock, etc.
19) Put the door panel back on--angle it on at the bottom of the window, and snap it down--work it on, and take your time. Be sure the lock plunger is sticking up through its hole.
20) Lie on the ground again, and reconnect all your wiring plugs.
21) Test your wiring--power windows, power locks, stereo, trunk release, door courtesy light. Test the door handle again. Test the lock plunger.
22) Fasten the panel back on. Hopefully, you won't have any extra or missing screws!
23) Close the door and test it. Test it from the outside, too.
That's it. Took me about 2 hours total.
It would have been shorter, but I wasted 20 minutes trying to get the lock cylinder out, then had to take the old handle to a place to hacksaw the lock cylinder tube apart, and then it took me a good 20 minutes to figure out how to thread the handle electric connection back around the window track.
Good luck!
The Pacific Northwest--Home of Legendary Mountains and Legendary Cars
dmjole is offline   Reply With Quote
DIY - Shock Removal Ballistic DIYs 22 02-06-09 08:44 PM
Claybar DIY (56K unfriendly) FF Drifter Second Generation Legend (1991-1995) 48 05-28-08 03:22 AM
Claybar DIY (56K unfriendly) FF Drifter DIYs 22 01-03-07 06:10 PM
Car Sale Gone Sour AcLegndTyp2 Second Generation Legend (1991-1995) 23 11-17-04 01:10 PM
You might be a ricer if ..... vrb747 The Lounge 17 06-08-04 12:30 AM
