DIY - Shock Removal - The Acura Legend & Acura RL Forum
Old 07-28-05, 09:57 PM   #1 (permalink)
iTrader Score: 7 reviews
DIY - Shock Removal
DIY - Shock removal
Stock removal can be done a few ways. Here is a picture of ALL the nuts and bolts required to be removed.
Step 1. Lift the car off the ground AND unscrew all the ABS and brake wires/hoses. You don't have to remove the calipers.
Step 2. Remove the (3) 14mm nuts from inside the engine bay
not to remove the one in the middle since it is under pressure from the spring.
step 3. Remove the Shock TO stock fork bolt. You will need a 17mm Socket
step 4. Now remove the fork bolt and nut. A 17mm socket is required. AFter you do this, the assembly will fall onto the axle. I would but a cloth inbetween the axle and stock fork just to be safe.
step 6. Now, to give yourself some extra space to work with, remove the upper control arm. Do do this, remove the (2) 17mm nuts in the engine bay.
DRIVERS SIDE: You can easily access them.
PASSENGER SIDE: You will have remove 2 bolts on the fuse box and use a wrench to get inside there.
Passangers side Upper control arm bolts:
ONce the upper control arm is free, do not remove it from the knuckle. Just let is hang there.
CAUTION: Do not pull the knuckle to far away from the car or the inner axle might pop out of the halfshaft and then you'l have to remove the axle to correct this.
Now you'll have enough space to remove the Shock.
To install, I recommend you first connect the top of the shock to the engine bay (as in step 2).
CAUTION: Do not pull the knuckle to far away from the car or the inner axle might pop out of the halfshaft.
Old 07-28-05, 10:01 PM   #2 (permalink)
has left the building
iTrader Score: 14 reviews
Goddamn, G. Nice DIY but I hope that's not your car that you're demonstrating on. That thing's all to pieces---
Old 07-28-05, 10:02 PM   #3 (permalink)
nah, my beater car. Gone tomarrow
Old 07-28-05, 10:03 PM   #4 (permalink)
Taking all of the usable sh1t off before disposal? Good move---
Old 07-28-05, 10:09 PM   #5 (permalink)
yupppppp . spare brakes, calipers, rotors, axles, half shaft, abs sensors.... and thats just the suspension.
Old 07-28-05, 10:13 PM   #6 (permalink)
Car 1: 1991 Gold Acura Legend LS
Car 2: 2006 Toyota Sienna
nice diy but you may want to tell people NOT to remove that nut in the middle of the strut... struts kill.
robbanks111 is offline   Reply With Quote
Old 07-28-05, 10:17 PM   #7 (permalink)
nut in middle of strut?
EDIT: for spring removal?
Old 07-28-05, 10:22 PM   #8 (permalink)
K L E A N M O D
Thai.95LCoupe's Avatar
Car 1: 1995 KA8 *R.I.P*
Car 2: 1997 S14 *SOLD*
Car 3: 2004 GTO
AWSOME!
-1995 KA8 MODIFIED-R.I.P
-1997 S14a-SOLD
-2000.2 Millenia S- Blown & SOLD
-1996.8 S14a-SOWED
-1995.8 S14a- SOLD
-2004 GTO-R.I.P
-1998 S14a
-Holy Rollerz CCC Member-
Imitatated. Never duplicated.
Thai.95LCoupe is offline   Reply With Quote
Old 07-28-05, 11:07 PM   #9 (permalink)
yes in the second pic when you say to remove the three nuts that hold the strut in place make a point to tell people not to remove the one in the middle since it is under pressure from the spring. never assume people know what you know.
Old 07-28-05, 11:38 PM   #10 (permalink)
gotcha thanks!!! ADded it in
Old 11-15-05, 09:04 PM   #11 (permalink)
engineering fanatic
Car 1: 95 L sedan
Need to change my shocks
I've been searching on the site, and I found this thread.
Question: I need to change the shock. How do I continue from the end of these instructions
IMDKING is offline   Reply With Quote
Old 09-17-06, 01:57 AM   #12 (permalink)
Telion's Avatar
Car 2: White 91 KA8 JDM TII
iTrader Score: 45 reviews
Send a message via AIM to Telion Send a message via MSN to Telion Send a message via Yahoo to Telion
ok so what if the knuckle joint dies come out, because I think mine did I cant get my upper control arm to go back into place. and it feels like my axle has slipped out but Ican still turn the wheel and get the other wheel to turn too. . . help
http://i300.photobucket.com/albums/nn20/Telion007/smallsig.jpg
http://firesignsynergy.spaces.live.com
3.5 TwinTurbo,TII springs & manifold,Telion Chip, HID's, D2 coilovers,Addco bars,TII calipers,RH C2's,R.J. shifter, 3"exhaust, hiflow cat,StageIII clutch,S&D rotors,KVR pads,Blackend damper,CF hood,AFC NEO,AEM FIC,Aluminum pulley,C&R Racing radiator,Garrett T3/T4 Turbos,Tial wastegates,Topfuel BOV,Fujita filters & Prosport guages. Pretty damn fast and far from done.
Telion is offline   Reply With Quote
Old 09-17-06, 11:28 AM   #13 (permalink)
I do not have a shock disassembly DIY. I can tell you a spring compressor will be needed. A warning: the spring is under extreme pressure and will spring up into your face if you remove the hardware keeping it down.
I'm a little lost... You should place the axle though the knuckle first, then use the hub nut to secure it into place. Then move the upper control arm outwards (towards you) and then slide the axle into the differential. I then held the top of the knuckle and pushed it towards the car in order to get the axle to "pop" it into the differetial.
Did you read my caution: CAUTION: Do not pull the knuckle to far away from the car or the inner axle might pop out of the halfshaft and then you'l have to remove the axle to correct this. You might have to remove the boot
Old 10-22-06, 09:31 AM   #14 (permalink)
Great stuff guys, I am wondering if there is any DIY on the rear shock removal and install?
Legend6662 is offline   Reply With Quote
Old 10-22-06, 02:39 PM   #15 (permalink)
Telion's Avatar
I have a lot of pics that I can add to the front shock DIY if anyone needs them until I add them in send me a PM with your email address and I will email them to you.
DIY - EGR Removal Pics Ballistic DIYs 46 11-12-19 03:11 AM
DIY - Cabin Filter Removal Ballistic DIYs 23 05-02-14 04:14 PM
Rear Shock removal Question (coupe) 2acurafreaks Engine & Performance Modifications 1 08-10-03 11:29 PM
