Diy: Window Motor Repair - The Acura Legend & Acura RL Forum
Ľ Auto Insurance
Ľ Wheel & Tire Center
Old 09-25-05, 05:24 PM   #1 (permalink)
swift's Avatar
Car 1: 92' C35 KA8 5spd
Car 2: 92' Ka8 5spd turbo
Post Diy: Window Motor Repair
*Only attempt this fix if you have patience, mechanical skills, and have tested the master switch etc for a voltage to the motor.
supplies:
This was done on a rear coupe motor.
#1) remove rear seat
2) undo screws on side panel and pry out and up carefully.
3) Undo harnesses.
4) undo the three bolts holding motor and lift up and out.
the motor:
I did not figure out how to undo cables so i did this all while sitting in back of car.
After taking out the two screws holding the silver cap containing magnets:
Inpect brushes
The main winding armature with unscrew kinda lefty loosey i believe and pop out off of gear inside.
The brushes go where the springs are located and the springs pushes brushes on the COM. MAKE SURE U INSTALL PROPERLY! Hold them in by putting fingers on the copper wire and hold them in and back while installing winding armature.
Brushes and springs:
ARMATURE:
Clean COM, armature, inside metal cap, and the area of the brushes from all the residue and worn out grease, use the replacement grease on gear area and on spring area(NOT ON COM).
Reinstall with care if brushes are intact and everything looks fine.
PS-This trick works on the Cruise control motor and saved me $500, and mom said i wouldn't gain anything from playing with the ol' tamiya RC truck
Old 09-25-05, 05:26 PM   #2 (permalink)
swift's Avatar
k
ATTN: MikeD or others, please transfer to DIY section
thanks much.
215whp+
Old 09-26-05, 11:57 AM   #3 (permalink)
Car 2: 1999 Acura 3.5RL
Car 3: 2004 GMC Sierra Z71
thanks much.
Done.
DIY Slow window lubrication rundmsef DIYs 42 08-21-11 03:14 PM
DIY: Lighted Window Switches GoldenCoupe DIYs 67 03-21-08 11:13 PM
DIY - Rear window does not roll up or down ZiGGie DIYs 5 09-13-06 04:44 AM
Please HELP! I have internal window problems! Sh0ck3d Second Generation Legend (1991-1995) 1 07-06-02 08:23 PM
