Replacing / Installing Pass Air Bag (SRS) - The Acura Legend & Acura RL Forum
Old 02-08-05, 05:15 PM   #1 (permalink)
Cool Replacing / Installing Air Bag (SRS)
Anyone Know how to replace the passenger side air bag with a new one?
Or a DIY would be great. Use searched but coudln't find anything. THanks
When I Replace my Air bag, I'll take pictures and make a DIY for you guys, I'll the first in the legend forum HIstory to do so.. I'm so excited. If any one would like to add anything feel free. Thanks!
phan_nam420 is offline   Reply With Quote
Old 02-09-05, 06:04 AM   #2 (permalink)
Oh hey, i checked legendtuner.com and i think he might be able to do the DIY for the air bag.
Old 02-09-05, 06:26 AM   #3 (permalink)
has left the building
iTrader Score: 14 reviews
If you are replacing air bags, you probably need a HELM manual. Best $80 you will ever spend on your car. Passenger side is not easy---3 bolts hold it to the cross brace and and there's a clamp arrangement on each end of the bag that cannot be gotten to unless you have a LONG magnetic screwdriver. Also, be sure to disconnect your battery before you do any SRS work.
You haven't lived until an airbag goes off in your face. Trust me on this one.
Old 02-09-05, 06:30 AM   #4 (permalink)
iTrader Score: 7 reviews
Updated Version (v2.3 optimized)
STEPS:
1. Disconnect the Battery
2. Remove the Courtesy light assembly. It is help in with 3 plastic screws. Then just pull it out. Once you have it loose, remove the plug for the light.
3. Once it's removed, you'll have to remove 4 screws. they hold in the glove box.
4. Now you'll have to unclip the top part. 3 clips hold it in. I used a flat knife to pry it off. Becareful not to break the clips.
5. You will now have the glove box removed. I forgot, but there might be a harness you'll have to disconect for the TRUNK release button.
6. There is not much space to work with. You'll to look up and find the main beam:
7. First, disconnect the airbag harness from the SRS harness and plug the airbag harness into the RED plug. AS SHOWN:
8. Now, you'll have to remove 6 bolts that clamp down the airbag. (you'll need an extention for your ratchet set to get up there)
If you feel that you can wiggle the airbag out, ignore #9.
*****9. I forgot, but you might need a screw driver to remove 2 screws on each side of the airbag. Steiveray said they are clamps also. If you have to, remove these 4 screws.
10. At this point, you should only have to pull up. It's gimmied in there, so wiggle it around. Becareful not to damage the dashboard.
Installation is in reverse.
Old 02-09-05, 06:33 AM   #5 (permalink)
oh, it's not that hard.
Old 02-09-05, 08:09 AM   #6 (permalink)
Steiveray talked about some clamps. I kindof remember removing 2 screws on each side of the airbag when I was figuring out how to do it myself. This woudl Be there location:
All you need is a long long screw driver to get up there.
(circled in RED)
Old 02-09-05, 12:53 PM   #7 (permalink)
Cool Gosh your fast!
I was going to do it this weekend, and figure it out but damn your quick!
Thanks Ballistic! Now i can do this faster. THANKS BRO! you da maN!
Gotta aquestion though, when you instlal the new one is it vise versa ? or is there a trick?
I haven't touched my SRS yet. But any suggestions or help is appreciated!
Old 02-09-05, 02:00 PM   #8 (permalink)
Originally Posted by MikeD
Thomas,
you info is EXCELLENT. Your pics rocks !!! I believe it's time to move the thread into the DIY forum. Those phat infos belongs in the DIY thread. Great info, Thomas !!! -Mike
thanks mike
assembly is the opposite, no tricks.
i'll give you an upgraded version on this DIY wed/thur (your PM)
Old 02-18-05, 04:55 AM   #9 (permalink)
Pretty work, Ballistic. I called them clamps because I didn't know what else to call them. :p Once you figure out how it's done, it's really not that hard.
found out my steering radio control wiring has failed Octane Audio, Video, & Electronics 14 11-24-05 10:43 AM
Steering Wheel Removal pecan2phat DIYs 4 06-08-05 02:09 AM
For Sale Driver Air Bag DJPolak OEM Parts 0 10-04-04 12:27 PM
Air bag, fog light, chip legend_life Engine & Performance Modifications 2 09-23-03 04:54 PM
Air bag question??? jrock7791 Second Generation Legend (1991-1995) 3 04-24-02 11:20 AM
