Throttle Body Cleaning ! - The Acura Legend & Acura RL Forum
Old 07-03-04, 12:29 PM   #1 (permalink)
Stu
Car 1: 2005 Lexus LS430
throttle body cleaning.
I am going to attempt to clean my throttle body myself and was wondering ...
can it be well cleaned while its on the car, or should it be removed ? If I clean it when it's on the car, is it necessary to put a small brush inside the part ?
If there are DIY instructions avaiilable, please point them out cause I searched expecting to find some but didn't. I know where the throttle body is and THATS ABOUT IT !
Thanks
Stu is offline   Reply With Quote
Old 07-03-04, 12:32 PM   #2 (permalink)
remove it. all you will need is a new gasket, which is like $4 at any auto part store.
i would remove all of the sensors, as well as the throttle cable. then scrub it with a wire brush, then with sand paper. you can remove the butterfly also
Old 07-03-04, 02:00 PM   #3 (permalink)
Car 1: 1991LS Sedan
Car 2: 89 CRX Si
Send a message via AIM to ikata
If you want to do a good job definitely remove it. I would shy away from messing with the TPS. It's a PITA to install and calibrate properly. Also wire brushes and sandpaper can be easily abused so if you are not confident in your skill go with something less agressive (scotchbrite comes to mind). Finally automotive stores sell dedicated TB cleaners but I have always found GUNK Engine Brite to do the best job. For the crowning touch use the foamy one. Easy around the sensors with this stuff. Good luck!
91 LS sedan...
89 CRX-Si...
loving it both ways...
ikata is offline   Reply With Quote
Old 07-03-04, 02:04 PM   #4 (permalink)
Lexus owner, dont hate me
midwestlegend's Avatar
Car 1: 1995 Lexus LS 400, silver on tan leather, 95K.
Arent the throttle springs on the right of the throttle body connected to it? If so will it come off as a full unit away from the throttle body, or does it stay connected once you get it off?
midwestlegend is offline   Reply With Quote
Old 07-03-04, 02:14 PM   #5 (permalink)
Car 1: 1991LS Sedan
Car 2: 89 CRX Si
Well... There are several coolant lines and electrical plugs that need to be disconnected and the cruise control and the accelerator cables but you can remove it from the intake manifold. Make sure you have plugs for the coolant lines or drain some of the coolant. Messy otherwise. Coolant bad for shiny engines parts
91 LS sedan...
89 CRX-Si...
Old 07-05-04, 03:32 PM   #6 (permalink)
Stu
well I keep looking but have not touched it yet. Bought a Haynes manual, almost useless. I am sure I could remove it and clean it, its just that I dont trust that afterwards the car will start ! A dealer would probably charge me $120 and who knows how well they would clean it. I wish I had a mechanic !
Old 07-05-04, 03:50 PM   #7 (permalink)
Car 1: .
Go to advance auto and spend less than $10 on a gasket and throtle body cleaner. Remove the accelerator and cruise cable. Detach coolant and vacume hoses. After this you only have one sensor to remove. 4 bolts and the throttle body is off. Then clean it with the tb cleaner and a tooth brush. Tighten the idle adjustment screw and count the number of turns to tight, then remove the screw. Spray the claner inside the screw hole. Put the idle adjustment screw to tight and then back it off the same number or turns you used to tighten it earlier. Reinstall throttle body and all lines with a new gasket. Make sure you clean off all of the old gasket. After it is all hooked up start the engine. Adjust the idle adjustment screw until you idle between 700-750rpm. Now you are done. Enjoy!
Later!
Lee
Old 07-05-04, 04:00 PM   #8 (permalink)
Stu
Originally Posted by sleeprlegendcp
Remove the accelerator and cruise cable. HOW ?
Detach coolant and vacume hoses. HOW ?
remove one sensor HOW and WHERE ?
Tighten the idle adjustment screw Where is this ?
then remove the screw. If I do this I am screwed !
I do know enough to say this is NOT a DIY project for me, but I do appreciate the effort to help me. Thanks to everyone !
Old 07-05-04, 10:03 PM   #9 (permalink)
AKA Smartjay28
Johnny Kim's Avatar
Car 1: JDM KA7
Car 2: w203
heres a tip. when you remove the coolant line(theres 2 of them if you didnt do the trottle body by pass thinyg) just shove them in the bolt where the trottle body hangs on.
like, theres 4 bolt, just stick the coolant line on the bottom two.
Old 07-06-04, 01:03 AM   #10 (permalink)
LPB
I just had mine off the vehicle. The gasket P/N 161-P5A-004 is $3.24 from Acura of Augusta. You shall need a torque wrench to reinstall (16 lb-ft). Be careful in the removal of the Cruise and Throttle Cables; loosen only the inside nuts so that the cable adjustments remain as they are. You shall need to block the coolant hose lines as coolant is not good to get on belts.
Old 07-06-04, 01:22 AM   #11 (permalink)
RAP
Car 1: '95 Legend 3 ea. 240SX
What! You giving up already?
What made you think that the throttle body needed cleaning in the first place?
Actually if you aren't comfortable in your abilities you should find a friend for comfort preferable one with some mechanical know how. This is not a hard job but if not done correctly problems with the engine running and idling will ensue.
RAP
Acurite
Old 07-06-04, 01:22 AM   #12 (permalink)
Stu
see, if I had gone ahead before LPB posted this, I would be messed up. I am going to try to find a local shop where I can pay and watch them do the work, so next time I will be able to do-it-myself !
anyone in Toronto who has done this before want to do this with me ?
Old 07-06-04, 01:38 AM   #13 (permalink)
AKA Smartjay28
Johnny Kim's Avatar
Car 1: JDM KA7
Car 2: w203
ok, ima geather up some pictures from this board, and ill try to help you out...
juz giv me a min to circle up some stuff on da pic.
brb
Old 07-06-04, 02:16 AM   #14 (permalink)
AKA Smartjay28
Johnny Kim's Avatar
Car 1: JDM KA7
Car 2: w203
ok, here it goes...
IF I MISSED SOMETHING, LET ME KNO.
Cole, you have IM,regarding your pictures.
if you take a look at the cables, you'll notice that theres a nut at each end of the 'holder' so a person can adjust the cable. just lossen the inner one(closes to the the back, viewing from the front)
to get the cables 'unhooked' from the levels, just pull the level (WOT) and slide it to the side) and another, dont forget to 'mark' which cable goes to which side.
when you remove the coolant line, theres gonna be some seepage, clog it w. a bolt or something. and make sure you fill up wat came out and bleed.
now cleaning, just use some carb&choke/trottle body cleaner and a toothbrush.
and bout the idle adjustment screw, i didnt do it but if you want to you can.
installatin is reverse, just remove the old gasket and replace it w/ a new one.
good luck
Old 07-06-04, 02:37 AM   #15 (permalink)
Stu
Thanks a lot !
Now that helps me out a lot ! I will wait a few days (just in case anyone wants to add anything) and then I will do this !!!
Fantastic ! Thanks again !
DIY: [Throttle Body Coolant Bypass] Cole Austin DIYs 75 06-07-12 04:39 PM
throttle body coolant bypass???? Seeb_95Legend Engine & Performance Modifications 16 02-08-05 08:02 AM
How to clean the throttle body?????? JOKER4INK Second Generation Legend (1991-1995) 2 06-15-04 02:50 PM
Throttle body cleaning...... Silver Second Generation Legend (1991-1995) 18 02-20-03 12:49 AM
