2nd to 3rd slip on 89 trans - The Acura Legend & Acura RL Forum
Old 09-14-04, 03:02 PM   #1 (permalink)
Car 1: 1990 Legend Legend Coupe
Car 2: 1992 Legend Sedan
What would cause the trans to slip from 2nd to 3rd. Its kinda like a delayed shift. The revs. increase and if then shifts, just a little slip (i guess) but sometimes when the car is cold the trans is stuck in 2nd. I have drained and refiled the trans with honda atf 3 times and cleaned the solenoids about 6-7 times. before I did that the car would only shift from 1st to 4th. I now just want to get rid of this problem. Could it be a clutch pack or something, trans fluid pressure? and should I ad a filter? as there always seems to be debris on the solenoid screens even after a week.
P.S. will a 90 trans work in a 89 I know the tcu is different.
mattpalmeris is offline   Reply With Quote
Old 09-14-04, 03:37 PM   #2 (permalink)
MrSmith's Avatar
Car 1: 90 Legend LS
Sorry Im not able to answer all your questions but a 90 Transmission is all alone. no other transmission made on the legend goes with the ninty.
I have a 90 and I looked and looked and all mecanics told me the same thing.
BUT!! I think with swapping here and there you could get it to work.
http://www.photoworks.com/servlet/GetThumb;jsessionid=70EBEB2BC8A8D21E005E6C775E13B4  FB?441778305,300x400,0,0,null&cb=PW&svr=web25
MrSmith is offline   Reply With Quote
Old 09-14-04, 11:42 PM   #3 (permalink)
InksBeMe
GREYLEGEND's Avatar
Car 1: 89 Sedan L, 270,000 km
Could be a number of things. Two make the tranny salvageable if they are 1. Test for Throttle Valve adjustment. You make this just tight enough and a little extra to make the line pressure higher. AKA kickdown cable. Look up the honda online manual on the stickie.
2. Drop in some Auto-RX to clean out the valve bodies inside if the tranny was not maintained with yearly drain and refills previously.
GREYLEGEND is offline   Reply With Quote
Old 12-02-05, 08:11 AM   #4 (permalink)
Car 1: 90 legend
I have A '90 legend L Auto, and a similar problem.
If I don't warm her up for a long time, it won't shift up to 3rd & 4th gears.
Also if I drive it while it's warming up (only 2nd gear) at some point it will rev up, as in Neutral, but this will only last a few seconds at most, then it shifts up and runs great (I usually let off the gas for several seconds, then tap the gas, and it will be ok).
I Changed the fluid (3X) shortly after I bought it (about 170,000 mi) to clear out the fluid from the tourque converter, etc.
It has done this since the day after I bought it. It now has about 185,000 mi.
Any chance it could be a solenoid, or sensor, or are the clutch plates the only likely source of the problem??
Anyone else out there have any info - advice..?
Also in looking for used trans (and other parts) I find 86-89, and 91-95... ? Is the '90 "special" or the same as 86-89?
skip is offline   Reply With Quote
Old 12-02-05, 10:05 AM   #5 (permalink)
Car 1: 1989 legend coupe
sounds like the shift solenoid screen is plugged and the ATF can't pass through it when cold and thick but can when thinned out a bit by the heat.
jmm67 is offline   Reply With Quote
Old 12-03-05, 03:22 AM   #6 (permalink)
Car 1: 90 legend
Ok, thanks.
Where is it and how can i check it?
Is there a DIY on it?
BTW, mine only slips when it its warmed up just enough to start to shift up to 3rd, once in 3rd. it is fine.
Old 12-03-05, 03:32 AM   #7 (permalink)
cigarettcancerman's Avatar
Car 1: 90 acura legend L
Send a message via AIM to cigarettcancerman
mine will slip from 2nd to 3rd but only if i im at full throttle, its not really a slip since the rpms dont go crazy, they just stop and chill for a second, its more of a hesitation, i could be wrong though, at that high of a rpm a slip isnt gona be able to rev up that much lol
[B][COLOR="Red"]My legend has been sold!
New car...
Black 5spd 93 integra GS hatch back
MP3/CD player
100w (500 RMS) profile amp
100w (600 RMS) Dual 12's bandpass
4 280w Pioneers
Red calipers
Factory alloy rims
STILL NO FACTORY CUP HOLDER!!!!!
cigarettcancerman is offline   Reply With Quote
Old 12-03-05, 08:24 PM   #8 (permalink)
Car 1: 90 legend
Trans. codes
Ok.
I checked the trans. code box, under the Pass. seat (from the back).
It blink 1 real long, then fast 12 times. I had found a link to a chart in another thread on this but there was NO code for 12..?
Is that bad? Am I reading iot wrong?
Any Ideas?
Old 12-05-05, 01:19 AM   #9 (permalink)
Car 1: 90 legend
Found it:
For Code 12, I had that, and it was the coolant temp sensor, located right below the intake, under the distributor (I think) It will hesitate shifting gears when I drive it first thing in the morning, then all is well after 5-10 min. ~ redlegend
Old 12-05-05, 02:34 AM   #10 (permalink)
Car 1: 90' legend 4dr, 88 legend 2dr
These tranny's are good but delicate, and the there are only 3 differences from the 90 to 89, housing with sensors, computer and the 90 doesn't have a shaft assembly for the sensor. All other internals are the same. Change the fluid every other oil change and it last a long time.
http://www.cardomain.com/ride/2159826
90 legend 4 dr
phantom grip lsd
custom 1 1/4 front sway bar
custom 7/8 rear sway bar
custom drilled rotors
custom 2 1/2 exhaust
zex NOS 75 shot
ss brake lines
acura TL coil over kit
custom built muffler
twin turbo legend comming soon
Johnny's Legend Speed Shop
john bigonion is offline   Reply With Quote
Old 01-26-06, 06:48 PM   #11 (permalink)
Car 1: 88 Acura Legend Coupe
This is what mine is doing now. Last week Tue, Jan 17th the lower ball joint on the driver side came appart and the car hit the ground hard. put it back together and it made a grinding noise when I put it in gear then two days later it did not make this noise and it seemed to shift fine, now this. Mine is doing the same as yours Cigarettcancerman. ????How is this corrected?????
undefined1stGenAcura
The car that is worthy of great mods.
1genacura is offline   Reply With Quote
Old 02-02-06, 09:58 PM   #12 (permalink)
Car 1: 1986 ack legend
My ack does the same thing. When you accelerate and it shifts from 2nd to 3rd it seems as though it slips. The rpms increase and then it shifts. once its in 3rd its fine.
real mckoy is offline   Reply With Quote
Old 02-02-06, 10:05 PM   #13 (permalink)
Spiral descent
telafonic's Avatar
Car 1: 1994 GS 6-speed
Car 2: 1996 A6
iTrader Score: 11 reviews
My '87 auto did this too. We don't have external solenoids or a TCU, so this problem is most likely mechanical, and to fix it, would probably require a rebuild.
Changing the fluid often with Honda ATF still helps though.
telafonic is offline   Reply With Quote
Old 02-03-06, 12:44 AM   #14 (permalink)
Car 1: 1988 Coupe LS
Send a message via AIM to Joel Send a message via MSN to Joel
Mine was doing this recently. I tried cleaning the solenoids, changing the fluid, etc.. Nothign helped. About a month later it died.
Just changed it out with a rebuilt one though. (:
Joel is offline   Reply With Quote
Old 02-03-06, 05:01 AM   #15 (permalink)
Subur*** Legend
Shai_Hulud's Avatar
Car 1: 1998 Honda Integra Type-R
Send a message via MSN to Shai_Hulud
does the 89 4dr have a tcu?
Shai_Hulud is offline   Reply With Quote
2nd to 3rd slip on 89 trans mattpalmeris First Generation Legend (1986-1990) 0 09-14-04 02:57 PM
transmission gasket / trans filter Merlin the Wrench Second Generation Legend (1991-1995) 1 11-28-03 12:04 AM
Top speed 1st 2nd 3rd 4th? Mod89Coupe First Generation Legend (1986-1990) 1 04-18-03 06:20 PM
2nd to 3rd Shift JB86 Second Generation Legend (1991-1995) 3 09-17-02 07:43 PM
Better to look for manual trans? LV_legend The Lounge 6 09-05-02 03:09 AM
