air conditioning and idle problems - The Acura Legend & Acura RL Forum
Old 10-02-09, 08:13 PM   #1 (permalink)
I have a 90 acura legend. We replaced the compressor it gets cold but never
shuts off the ac button light never has worked. Also it will blow snow at me
when I turn it to outside air. It also blows warm air part of the time and then the blower will barely blow at other times. I have problems with the car dying when the
compressors is plugged in but not when it is unplugged. I would like to know what is the cause of these problems so we can get this fixed but don't know where to start.
avon is offline   Reply With Quote
Old 10-11-09, 04:23 PM   #2 (permalink)
Car 2: 1991 Sedan L
Sedan or coupe? Could be something as simple as the "rad fan control unit" (Acura part#37735-PH7-0230 ...about $170) ...on sedans, its located under the dash, directly above the gas pedal. About the size of a pack of cigarettes. Also, since you have already replaced the compressor, you might check to see that everything (wiring) has been reconnected properly. If its sucking in outside air directly, you may have a disconnected or broken vacuum line that controls the position of the internal flaps that direct air flow.
The Service Manual has a very comprehensive trouble shooting section for the A/C system. If you can't find it online, PM me and I can send you jpg or PDF files.
digger89L is offline   Reply With Quote
