Bleeding ALB System - The Acura Legend & Acura RL Forum
Old 07-29-04, 02:18 PM   #1 (permalink)
Bleeding ALB System
I have 1988 Acura Legend w/ the dual brake reservoir Honda ALB system. This is the Honda version of the ABS and I believed it's the 1st generation ALB system. Can someone tell me how can I flush out all the old brake fluid and in w/ the new? The Honda ALB system is simply too strange for me. I am more familar w/ the Bosch ABS. THANKS
samnt650 is offline   Reply With Quote
Old 07-29-04, 07:10 PM   #2 (permalink)
is there a reason for the flush? because adding new brake fluid can wear out the seals on your master cylinder and abs faster
amplified is offline   Reply With Quote
Old 07-29-04, 10:22 PM   #3 (permalink)
Car 1: 1989 LS Coupe
The "cheap and dirty" way is to use a turkey baster to remove as much fluid as you can from the ABS brake fluid reservoir, refill with fresh fluid, and cycle the ABS on a dirt or wet road. Repeat several times. Doing this essentially dilutes the fluid you have with new, and doing it enough times will eventually replace it all, or at least most of it.
chuckee98 is offline   Reply With Quote
Old 07-30-04, 12:01 AM   #4 (permalink)
paulo57509's Avatar
These instructions are for an NSX, but the NSX system is similar (if not identical) to the Legend.
ftp://members.aol.com/paulo57509/abs_nsx.pdf
'87 L-Coupe 5-Speed
Stock; NO Mods
438K Miles - original engine and drivetrain.
paulo57509 is offline   Reply With Quote
Old 07-30-04, 01:02 AM   #5 (permalink)
THANKS.. I'll give it a try tonight and let you all know how it goes..
Old 07-30-04, 04:36 AM   #6 (permalink)
where can you find the wrench to bleed the abs system??
Ackman is offline   Reply With Quote
Old 07-30-04, 04:42 AM   #7 (permalink)
I believe it is a dealer only part.
Bleeding cooling system: 93 legend Roger Smith Second Generation Legend (1991-1995) 1 04-02-04 11:48 AM
Cooling System Bleeding Procedure JimV Second Generation Legend (1991-1995) 32 01-08-04 01:42 AM
Bleeding Air Out of Cooling System FutureX 2001 Second Generation Legend (1991-1995) 7 05-20-03 12:54 AM
Question about Bleeding coolant system MadDog Second Generation Legend (1991-1995) 3 04-03-03 05:25 PM
Bleeding ABS System JamLegend Second Generation Legend (1991-1995) 3 06-28-02 12:48 AM
