car wont start - The Acura Legend & Acura RL Forum
Old 12-10-05, 09:56 PM   #1 (permalink)
car wont start
Alright Well My Car Use To Have To Be Kick Started But Now It Wont Even Do That It Does Nothin At All Yall Have Any Ideas If So I Would Like The Help
sprayin88ac is offline   Reply With Quote
Old 12-11-05, 04:25 AM   #2 (permalink)
Could just be a dead battery sprayin88ac... but, can you give us any symptom(s) to further assist you with your problem(s), like; engine will not rotate when attempting to start or engine rotates but will not start, or maybe; how many miles, your last tune up, etc., etc., that sort of thing, so we can give you a better diagnosis, yah know.
Old 12-11-05, 12:14 PM   #3 (permalink)
Timing might be off.....
Brent85 is offline   Reply With Quote
Old 12-13-05, 06:48 PM   #4 (permalink)
alright found out the coil had went bad so now it will kick start again i did a tune up like last week plugs wires cap rotor all that had starter checked it works, when you put the key in turn on turn key it does nothing at all, tried to put a push start on it but all the start with do is turn the gear wont come out to turn the motor thanx for any help
Old 12-13-05, 08:30 PM   #5 (permalink)
Could be a faulty/bad neutral safety switch...
Old 12-14-05, 05:41 AM   #6 (permalink)
ok i did a auto to manual swap on this car would that matter???
Old 12-14-05, 02:54 PM   #7 (permalink)
Double check your wirings and ensure that they're all plugged in and properly grounded.
Old 12-14-05, 03:02 PM   #8 (permalink)
k i have checked all that and it is all good to go.... umm thats what im not understanding is why it wont start.... but if anyone knows where to put the wire on the start to kick the cylinoid i would appreciate it..... i think i am going to replace all wiring in the car should be exciting.... but till then if anyone could i would appreciate it..... the things we go through for our cars
Old 12-14-05, 03:37 PM   #9 (permalink)
***ned
If you did a Auto to Manual swap than you need to run a wire from the starter solonoid to the start side of the ignition switch. This is because your neutral saftey switch is no longer there.
1_Hot_Legend_LS is offline   Reply With Quote
Old 12-14-05, 03:41 PM   #10 (permalink)
k thanx but do you know which wire that would be and..... why would it start sometimes just randomly.....
Old 12-14-05, 03:44 PM   #11 (permalink)
***ned
Hmmm, starts randomly? That means someone already did the neutral bypass. I would then guess that if the starter is only cranking at random times and you have to push start the car then the starter is bad.
Old 12-14-05, 03:51 PM   #12 (permalink)
thats what i thought but i took the starter out took it too autozone had them check it and it worked fine no problems.... this why i want to just put a pysh button start and forget about it but when i did that all the starter did was spin zzzzzzzzzzzzzzzzzzzz but the cylonoid was nt kickin the gear out.... i think i just put the wire on the starter in the wrong place but i am not sure....
AHH! Stupid car wont start LacyTheLegend Second Generation Legend (1991-1995) 13 10-20-05 12:31 AM
Help car wont start cbr900bikes Second Generation Legend (1991-1995) 6 07-23-03 12:28 AM
Car Wont Start - I have removed thee Thermostat! AlanJ Second Generation Legend (1991-1995) 1 08-03-02 05:16 PM
HELP... My car won't start!!!!! jewelerz Second Generation Legend (1991-1995) 7 06-16-02 01:15 PM
Installing Remote Starter - PAIN pYmpdaddi DIYs 34 03-18-02 12:37 AM
