Ecu throwing a code 9 - The Acura Legend & Acura RL Forum
Old 12-14-05, 02:18 AM   #1 (permalink)
How do I go about fixing this? Is it as simple as a sensor that needs replaced? If I was to take it to a mechanic is this a big $$$ fix? Thanks
jeighty3 is offline   Reply With Quote
Old 12-14-05, 03:10 AM   #2 (permalink)
Car 1: 1989 legend coupe
code 9 is #1 cylinder position, I have no idea what it means though.
jmm67 is offline   Reply With Quote
Old 12-14-05, 03:21 AM   #3 (permalink)
Car 1: Granada Black '90 Acura Legend L Sedan (Sold) Car 2: Grey '87 5-speed Legend L Coupe.
Car 3: Maroon '86 Accord
Send a message via AIM to tedhodges Send a message via Yahoo to tedhodges
No. Cylinder Position Sensor.
Were you getting ready to replace your timing belt and water pump?
I hope so, look into spending between $700 and $1300 (depending on where you go and if you get the timing belt and water pump done).
This is me:
tedhodges is offline   Reply With Quote
Old 12-14-05, 04:19 AM   #4 (permalink)
Sensor detects position of #1 cylinder, it uses a signal to trigger the sequential fuel injection... cylinder sensor is located behind the camshaft pulleys on the left or front bank of cylinders for all g1 (coupe/sedan) legends.
It could also be a sign of a faulty/bad distributor in which the cylinder sensor signal is generated by the rotation of toothed wheels passing through the pick-up coils.
... more suggestions;
https://www.acura-legend.com/vbulleti...ylinder+sensor
... hope this helps and good luck
ECU code 12 (EGR fault) 300000legend First Generation Legend (1986-1990) 1 12-04-05 07:52 PM
WHAT!!! Look at this......and to think how long I have been looking for this!!!!!!!!! sr79labrat Engine & Performance Modifications 9 11-30-05 03:31 AM
Help Again!!!! 2.7legend First Generation Legend (1986-1990) 67 10-23-05 11:16 PM
Road trip story and ECU code 12 Kasteman Second Generation Legend (1991-1995) 1 12-03-03 09:02 PM
What ECU code is this??? 90LegendCoupe First Generation Legend (1986-1990) 13 02-07-03 06:37 PM
