LED Dash Lights? - The Acura Legend & Acura RL Forum
Old 05-12-10, 03:59 AM   #1 (permalink)
black28's Avatar
Car 1: 1990 Acura Legend
Car 2: 2001 Honda Civic
LED Dash Lights?
has anyone converted their dash lights to LED's of any color? just curious, one of my future projects and wanted to know if our dash's and stuff have a exact fit LED Bulb we can get from superbrightleds.com or something. let me know. thanks!
black28 is offline   Reply With Quote
Old 05-12-10, 10:40 AM   #2 (permalink)
FRISCO LEGEND BABY!!!!
l4zy415's Avatar
Yup, I've got the bright white color for the dash lights. Even the door lights are bright white.
Old 05-12-10, 06:49 PM   #3 (permalink)
black28's Avatar
what sizes were the bulbs and how many did you need? post a link if you can. with a brief run through if you can. thank you
Old 05-26-10, 02:32 PM   #4 (permalink)
Car 1: 1989 Acura Legend L
so which ones are our dash lights? For the Superbrite LED?
mxsloan is offline   Reply With Quote
Old 05-26-10, 05:36 PM   #5 (permalink)
desola22's Avatar
Send a message via AIM to desola22 Send a message via Yahoo to desola22
legend101
Where I Need ToBe
All Over The Legend
desola22 is offline   Reply With Quote
Old 05-29-10, 12:04 AM   #6 (permalink)
because i can.
Car 1: '87L, 5 speed Sedan
Car 2: '71 Datsun PL521
Car 3: '03 Infiniti I35
iTrader Score: 14 reviews
Originally Posted by desola22 View Post
legend101
That makes zero fucking sense.
Old 05-30-10, 10:15 PM   #7 (permalink)
l4zy415's Avatar
Anyways, from superbrightleds.com, these are what I got:
For the top cluster lights, there are 3. I used T1.5 series LED Twist Lock Lamp. Once the pop-up window comes up, its under T1.5 Instrument LED bulb.
For the switches around the cluster, I used NeoWedge series LED Lamp. One the pop-up window comes up, its under NEOx High Power LED Instrument bulb. They 3 sizes 3mm, 4mm, and 5mm. The Emergency blinker, Rear Window Defroster, and Cruise switches uses 4mm. The Light Adjuster, and Radio switch uses 5mm.
For the map lights and door lights, under the LED Festoon Bulb, when the pop up menu appears, I used 3022-X4 LED Festoon Bulbs.
I have not completed my LED conversion yet, but thats some of the lights I replaced. I'll post pics of how they look. In order to have the white light effect, use a heat gun on the image in front and peel it back. Behind it is a blue film that you can remove so it doesn't look blue if you use the White LED light.
Old 05-31-10, 11:55 PM   #8 (permalink)
Car 1: Acura Legend 1986 gen 1
what abt the doorlights wat size r they?
angelmar06 is offline   Reply With Quote
Old 06-05-10, 09:36 AM   #9 (permalink)
black28's Avatar
hey would a blow dryer work for this as well instead of the heat gun? lol....i'm gonna order my bulbs today. was debating between white and Blue. maybe i'll mix it up. haha. i wanted a grey bulb since my car is gothic grey but they don't have it. i'll do a DIY for this when i get to is. havent taken apart the Climate Control yet, but i wonder if this would take similar bulbs as well. i know a site LEDautomotive.com that sells climate control kits for the civics. the dash bulbs are the T1.5's maybe they are the same for the climate buttons too.
for the hazard, radio, cruise, Rear Defr how did the bulbs come out? is there a film there as that needs to be removed?
Old 06-05-10, 01:20 PM   #10 (permalink)
l4zy415's Avatar
The blue film is behind the image on the switch. You can also use a blow dryer too if thats the only thing you have. Those bulbs twist off with a flat head screwdriver.
Old 06-06-10, 05:14 AM   #11 (permalink)
black28's Avatar
aight ima do that. hey bro what type of bulb was for the door lights? i'm thinkin of goin blue dash blue doors....if not then all white, or blue dash white door or whatever. still debating.
Old 06-07-10, 02:27 AM   #12 (permalink)
l4zy415's Avatar
I edited post number 7, I added more info.
Old 06-07-10, 06:12 AM   #13 (permalink)
black28's Avatar
thanks! i just ordered the High Power Whites, gonna keep all of the lights white. including door and map lights, don't wanna get pulled over for impersonating a cop. big big fine here. a friend got fined for having blue lighter wiper nozzles.
Old 06-10-10, 09:42 AM   #14 (permalink)
black28's Avatar
installed my LEDs, looks clean as shit! wasn't too hard. it was actually a little time consuming due to my oil and volt gauges...one thing though my rear def, radio, sun roof, hazard and light adjuster lights don't work and the bulbs were the wrong sizes. the light adjusters wouldnt fit. it was too big, and the others just don't work. the felt a little too big as well. i got 4 4mm's and 1 5mms. i disconnected my radio switch so i didnt get a bulb for that.other then that it looks real good.
Old 06-11-10, 02:21 PM   #15 (permalink)
l4zy415's Avatar
For the LEDs, sometimes you have to turn them the other way to get the to light up. If they don't light up, remove it, turn it and put it back.
