need advice... was told i needed to replace transmission strainer - The Acura Legend & Acura RL Forum
Old 10-22-09, 08:13 PM   #1 (permalink)
Angry need advice... was told i needed to replace transmission strainer
i have a 1990 acura legend. the car ran at first but now when it is time to shift from 1st to 2nd gear, i have to do it manually, otherwise it acts and sounds as if it is in nuetral.
LilBrian101 is offline   Reply With Quote
Old 10-22-09, 09:23 PM   #2 (permalink)
Car 1: 94 L Sedan
The strainer (really just a screen) cant be replaced without tearing down the transmission itself...clean your solenoids.
ihvnoclu2002 is offline   Reply With Quote
Old 11-15-09, 07:22 PM   #3 (permalink)
help my trans is acting up
what would be used to clean the transmission solonoids? whould a trans flush and conditioner help also? if you shift my trans into the second gear selection it dos not work why is that?
sinisterlegend1 is offline   Reply With Quote
Old 11-16-09, 05:50 AM   #4 (permalink)
Car 1: 91 legend ls
Car 2: 84 yamaha xt 250
i had the same problem. my transmission was stuck in 2nd and 4th and would only engage if i did it manually. i replaced the four pin harness right on the side of the transmission and now it shifts perfectly. easy and cheap
...........stock to tha bone...........
butters42 is offline   Reply With Quote
Old 09-30-14, 12:01 PM   #5 (permalink)
Car 1: 1988 legend 4 door
4 pin harness?
4 pin harness? I have the same problem. cannot find the 4 pin harness in the acura manual. what is it? thanks
89 legend LS 240K
replaced: O2, oil pan gasket, front and rear valve cover gasket, front and rea valve cover gasket, oil filter block O ring , antenna motor, right front upper flexible brake lines, catalytic converter, oil pump.
acuraowner1 is offline   Reply With Quote
