2004 Acura RL power steering problems - The Acura Legend & Acura RL Forum
Old 10-23-19, 12:17 PM   #1 (permalink)
I just had rack and pinion replacement and they said my pump was good, so why is it still hard to turn? Please.....
frogg1970 is offline   Reply With Quote
Old 10-23-19, 12:18 PM   #2 (permalink)
To steer
Old 10-29-19, 06:26 PM   #3 (permalink)
I would check 1: fluid level. 2# get the front 2 wheels off the ground and turn the wheel left to right slowly and steadily to force any possible air bubbles through the system. 3: the color of the fluid, dirty fluid can create problems with flow. 4: the sensor that separates from the return hoses, if you follow the 2 hoses that return to the reservoir you will find one that "t's" off into another hose that runs to a sensor, check that (I'll post a diagram to show you the hoses) check for leaks. Pressure = proper
Lil_Compton is offline   Reply With Quote
Old 10-29-19, 06:28 PM   #4 (permalink)
This picture is the hose "T" section leading to the sensor. I hope anything I've listed has helped you
Old 10-30-19, 04:33 AM   #5 (permalink)
You should check the fluid see if its below the basal line.
The legend is burted
road tax calculator malaysia
OmarYongt is offline   Reply With Quote
