I have gone through the serice manual and listed the DTC codes for the RL. These codes give a pretty good idea about what needs to be troubleshooted. For each code, there is about a page of flowcharts to diagnose the problem correctly. Feel free to contact me whenever a code pops up to figure out what needs to be done.
To read the codes, insert the service connector or the 2 ends of a wire into the 2 slots in the blue connector under the glove compartment. Turn the ignition to ON(II). The light will come on for 2 seconds. This is the test phases, do not count this inital one. After the light goes out, start counting the blinks. It will be long ones followed by short ones. (i.e. 3 long blinks and 5 short ones is a code 3-5) Sometimes you may have more than one code stored in the memory. The first code that blinks is the most recent. The ECU will store up to 3 codes for each light.
ABS:
1-0 Pump motor overrun
1-2 Pump motor
1-3 High Pressure Leakage
1-4 Pressure Switch
1-8 High Pressure System
2-1 Parking Brake
3-1 Right Front Pulser
3-2 Left Front Pulser
3-4 Right Rear Pulser
3-8 Left Rear Pulser
3-12 Different Diameter Tire
4-1 Right Front Wheel Sensor
4-2 Left Front Wheel Sensor
4-4 Right Rear Wheel Sensor
4-8 Left Rear Wheel Sensor
5-0 Right/Left Rear Wheel Lock
5-4 Right Rear Wheel Lock
5-8 Left Rear Wheel Lock
6-0 Front/Rear Fail-Safe Relay
6-4 Front Fail-Safe Relay
6-8 Rear Fail-Safe Relay
7-1 Right-Front Solenoid
7-2 Left -Front Solenoid
7-4 Rear Solenoid
8-1 ABS Function
8-2 CPU Comparison
8-4 Integrated Circuit
TCS:
*If both the TCS and ABS light are on together, troubleshoot the ABS first*
2-0 Parking Brake
2-1 Steering Angle Sensor
3-1 TCS Inhibition
3-2 Engine Speed Signal
3-4 Reference Voltage Signal
3-5 Barometric Pressure Signal
3-6 Throttle Position Sensor Signal
3-7 TCS Control Valve Sensor Signal
4-1 Right Front Wheel Sensor Signal
4-2 Left Front Wheel Sensor Signal
4-4 Right Rear Wheel Sensor Signal
4-8 Left Rear Wheel Sensor Signal
4-9 ABS Down
5-1 Fail-Safe Relay Stuck On
5-2 Ignition Switch Signal
5-3 Ignition Switch Signal
5-4 TCS Control Valve Actuator Initial Motor Operation
5-5 TCS Control Valve Actuator Motor Operation (1)
5-6 TCS Control Valve Actuator Motor Operation (2)
5-7 TCS Control Valve Actuator Over Limit Motor Circuit
5-8 TCS Control Valve Actuator Motor Driver Open
5-9 TCS Control Valve Actuator Under Limit Motor Circuit
5-10 TCS Control Valve Actuator Motor Driver Shorted
6-1 A/T Shift Position Signal
MIL:
*The P---- codes are recieved by connecting a OBDII reader to the computer. You can use the service connect/blinking light method to read the codes (those codes are in parenthesis) however there are not as accurate. Also some codes need to be read twice, some are only for certain models ect. Please contact me for further details regarding such codes*
P0106 (5) Manifold Absolute Pressure Circuit Range/Performance Problem
P0107 (3) Manifold Absolute Pressure Circuit Low Input
P0108 (3) Manifold Absolute Pressure Circuit High Input
P0111 (10) Intake Air Temperature Circuit Range/Performance Problem
P0112 (10) Intake Air Temperature Circuit Low Input
P0113 (10) Intake Air Temperature Circuit High Input
P0116 (86) Engine Coolant Temperature Circuit Range/Performance Problem
P0117 (6) Engine Coolant Temperature Circuit Low Input
P0118 (6) Engine Coolant Temperature Circuit High Input
P0122 (7) Throttle Position Circuit Low Input
P0123 (7) Throttle Position Circuit High Input
P0131 (2) Right Primary Heated Oxygen Sensor Circuit Low Voltage (Bank 1, Sensor 1)
P0132 (2) Right Primary Heated Oxygen Sensor Circuit High Voltage (Bank 1, Sensor 1)
P0133 (62) Right Primary Heated Oxygen Sensor Slow Response (Bank 1, Sensor 1)
P0135 (42) Right Primary Heated Oxygen Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
P0137 (63) Secondary Heated Oxygen Sensor Circuit Low Voltage (Sensor 2)
P0138 (63) Secondary Heated Oxygen Sensor Circuit High Voltage (Sensor 2)
P0139 (63) Secondary Heated Oxygen Sensor Slow Response (Sensor 2)
P0141 (65) Secondary Heated Oxygen Sensor Heater Circuit Malfunction (Sensor 2)
P0151 (1) Left Primary Heated Oxygen Sensor Circuit Low Voltage (Bank 2, Sensor 1)
P0152 (1) Left Primary Heated Oxygen Sensor Circuit High Voltage (Bank 2, Sensor 1)
P0153 (61) Left Primary Heated Oxygen Sensor Slow Response (Bank 2, Sensor 1)
P0155 (41) Left Primary Heated Oxygen Sensor Heater Circuit Malfunction (Bank 2, Sensor 1)
P0171 (46) System to Lean [Right Bank (Bank 1)]
P0172 (46) System to Rich [Right Bank (Bank 1)]
P0174 (45) System to Lean [Left Bank (Bank 2)]
P0175 (45) System to Rich [Left Bank (Bank 2)]
P0325 (53) Right Knock Sensor Circuit Malfunction
P0330 (23) Left Knock Sensor Circuit Malfunction
P0335 (4) Crankshaft Position Sensor 1 Circuit Malfunction
P0336 (4) Crankshaft Position Sensor 1 Range/Performance
P0401 (80) Exhaust Gas Recirculation Insufficient Flow
P0420 (67) Catalyst System Efficiency Below Threshold
P0452 (91) Evaporative Emission Control System Pressure Sensor Circuit Low Input
P0453 (91) Evaporative Emission Control System Pressure Sensor Circuit High Input
P0505 (14) Idle Control System Malfunction
P0715 (70) Automatic Transaxle
P0720 (70) Automatic Transaxle
P0730 (70) Automatic Transaxle
P0740 (70) Automatic Transaxle
P0753 (70) Automatic Transaxle
P0758 (70) Automatic Transaxle
P1106 (13) Barometric Pressure Circuit Range/Performance Problem
P1107 (13) Barometric Pressure Circuit Range/Performance Problem
P1108 (13) Barometric Pressure Circuit High Input
P1121 (7) Throttle Postion Lower Than Expected
P1122 (7) Throttle Postion Higher Than Expected
P1128 (5) Manifold Absolute Pressure Lower Than Expected
P1129 (5) Manifold Absolute Pressure Higher Than Expected
P1201 (71) Random Misfire - Cylinder 1
P1202 (72) Random Misfire - Cylinder 2
P1203 (73) Random Misfire - Cylinder 3
P1204 (74) Random Misfire - Cylinder 4
P1205 (75) Random Misfire - Cylinder 5
P1206 (76) Random Misfire - Cylinder 6
P1300 (71-72) Random Misfire
P1301 (71) Random Misfire - Cylinder 1
P1302 (72) Random Misfire - Cylinder 2
P1303 (73) Random Misfire - Cylinder 3
P1304 (74) Random Misfire - Cylinder 4
P1305 (75) Random Misfire - Cylinder 5
P1306 (76) Random Misfire - Cylinder 6
P1316 (79) Spark Plug Voltage Detection Circuit Malfunction (Left Bank)
P1317 (79) Spark Plug Voltage Detection Circuit Malfunction (Right Bank)
P1318 (79) Spark Plug Voltage Detection Module Reset Circuit Malfunction (Left Bank)
P1319 (79) Spark Plug Voltage Detection Module Reset Circuit Malfunction (Right Bank)
P1336 (54) Crankshaft Position Sensor 2 Circuit Range/Performance Problem
P1337 (54) Crankshaft Position Sensor 2 Circuit Malfunction
P1381 (9) Cylinder Position Sensor 1 Range/Performance Problem
P1382 (9) Cylinder Position Sensor 1 Malfunction
P1386 (59) Cylinder Position Sensor 2 Range/Performance Problem
P1387 (59) Cylinder Position Sensor 2 Malfunction
P1456 (90) Evaporative Emission Control System Leak Detected (Fuel Tank)
P1457 (90) Evaporative Emission Control System Leak Detected (Canister)
P1491 (12) EGR Valve Lift Insufficient Detected
P1498 (12) EGR Valve Lift Sensor High Voltage
P1508 (14) Idle Air Control Valve Circuit Failure
P1607 (-) Powertrain Control Module Internal Circuit Failure
P1690 (35) TCSTB Line Failure
P1696 (36) TCFC Signal Low Input
P1697 (36) TCFC Signal High Input
P1705 (70) Automatic Transaxle
P1706 (70) Automatic Transaxle
P1753 (70) Automatic Transaxle
P1758 (70) Automatic Transaxle
P1768 (70) Automatic Transaxle
P1791 (70) Automatic Transaxle
SRS:
1-1 Open in the Driver's Airbag Inflator
1-2 Increased Resistance in Driver's Airbag Inflator
1-3 Short to Another Wire in Driver's Airbag Inflator or Decreased Resistance
1-4 Short to Power in Driver's Airbag Inflator
1-5 Short to Ground in Driver's Airbag Inflator
2-1 Open in the Passenger's Airbag Inflator
2-2 Increased Resistance in Passenger's Airbag Inflator
2-3 Short to Another Wire in Passenger's Airbag Inflator or Decreased Resistance
2-4 Short to Power in Passenger's Airbag Inflator
2-5 Short to Ground in Passenger's Airbag Inflator
3-1 Open in Driver's Seat Belt Tensioner
3-2 Increased Resistance in Driver's Seat Belt Tensioner
3-3 Short to Another Wire in Driver's Seat Belt Tensioner or Decreased Resistance
3-4 Short to Power in Driver's Seat Belt Tensioner
3-5 Short to Ground in Driver's Seat Belt Tensioner
4-1 Open in Passenger's Seat Belt Tensioner
4-2 Increased Resistance in Passenger's Seat Belt Tensioner
4-3 Short to Another Wire in Passenger's Seat Belt Tensioner or Decreased Resistance
4-4 Short to Power in Passenger's Seat Belt Tensioner
4-5 Short to Ground in Passenger's Seat Belt Tensioner
5-1 Internal Failure of the SRS unit
5-2 Internal Failure of the SRS unit
5-3 Internal Failure of the SRS unit
5-4 Internal Failure of the SRS unit
5-5 Internal Failure of the SRS unit
6-1 Internal Failure of the SRS unit
6-2 Internal Failure of the SRS unit
6-3 Internal Failure of the SRS unit
6-4 Internal Failure of the SRS unit
7-1 Internal Failure of the SRS unit
7-2 Internal Failure of the SRS unit
7-3 Internal Failure of the SRS unit
8-1 Internal Failure of the SRS unit
8-2 Internal Failure of the SRS unit
8-3 Internal Failure of the SRS unit
8-4 Internal Failure of the SRS unit
8-5 Internal Failure of the SRS unit
8-6 Internal Failure of the SRS unit
9-1 Faulty SRS Indicator Circuit or Faulty SRS Power Supply
9-2 Faulty SRS Power Supply
10-1 SRS Replacement Code
ABS:
1-2 Pump motor
1-4 Pressure Switch
2-1 Parking Brake
7-4 Rear Solenoid
8-1 ABS Function
8-2 CPU Comparison
TCS:
2-0 Parking Brake
3-1 TCS Inhibition
4-9 ABS Down
MIL:
SRS:
