Tire Pressure - The Acura Legend & Acura RL Forum
Old 07-31-04, 06:18 AM   #1 (permalink)
Car 1: 1997 Green Acura 3.5RL
Tire Pressure
My 97 RL always looks under inflated at the front, even though the tire pressure is set correctly at 29 psi as per Acura spec. Rear wheels look fine. I just pumped it up yesterday to about 32 - 33 psi.
I was wondering what you guys do in terms of tire pressure.
ARVIN is offline   Reply With Quote
Old 07-31-04, 06:44 AM   #2 (permalink)
FF Drifter's Avatar
It is properly inflated; but remember that your car is significantly heavier in front than it is in the back ~ in your car... probably 59% of the weight is over the front wheels, giving them a squashed-down look. Acura knows what they're doing with the tire pressure recommendations. You have more contact patch up front which helps with handling. Besides, radial tires never look "completely perfectly round". Don't worry about it, as long as your wheels are at the correct pressure, you're fine.
Old 08-17-04, 04:58 AM   #3 (permalink)
You can also do your own data collection on your own vehicle as long as everything is up to par. Just monitor the tire wear. The huge sidewall on stock RL wheels and tires squish a lot. Its part of the comfort ride too.
3g Legend is offline   Reply With Quote
Old 07-09-19, 02:40 AM   #4 (permalink)
you cannot judge it tires are underinflated just by looking at them. stick to the recommended tire pressure levels set by vehicle manufacturer
Acura Tire Pressure
tireguru21 is offline   Reply With Quote
Dumb Tire Pressure Questions frantinez63 Second Generation Legend (1991-1995) 7 04-29-04 09:33 AM
Recharging 134 system... no pressure when system running.. theGodfather Second Generation Legend (1991-1995) 3 09-25-03 09:31 AM
Tire Pressure? andrew c levine Second Generation Legend (1991-1995) 15 08-14-03 08:36 PM
Tire Pressure 88Legend_SedanL First Generation Legend (1986-1990) 4 06-11-03 01:42 PM
Tire Pressure OEM 215/55/16 LPB Engine & Performance Modifications 2 04-24-03 07:47 PM
