ABS activating all the time - The Acura Legend & Acura RL Forum
Old 02-26-05, 03:05 AM   #1 (permalink)
FIXER
Ok, I replaced the passenger side axle for the second time in a week.The first one had a rumble at idle and vibration at 60-75mph. The rumble and vib are gone but now my ABS is activating as soon as I go over 5 mph. It is not giving me a code, just activating when I start rolling. I guess it has to be outer knuckle of the new axle. I looked at it and noticed that the pickup doesn't line up exactly with the ABS axle serrations. The left side lines up perfect. It's like the outer axle knucle is not going deep enough into the hub. I checked the axle nut and it is tight and appears to be all the way in.
Why me......I'm stuck in axle hell.
I had to pull the ABS fuses so I can drive it. I guess I'll have to pull it apart for a third time.
Anybody had this problem before?
Old 02-26-05, 03:15 AM   #2 (permalink)
I have the same problem, I believe we need to reset the gap on the sensor to axle. Not sure but I'm sure someone will know.
Paradise is offline   Reply With Quote
Old 02-26-05, 06:02 AM   #3 (permalink)
PSA
yup, the problem is with the axels.
PSA
PSA is offline   Reply With Quote
Old 03-01-05, 01:27 AM   #4 (permalink)
FIXER
I just pulled the axle and found that the ABS ring on the axle is loose and out of position. It is supposed to be a press on fit. I'm able to move it with my fingers. This is what's causing my ABS to activate.
So I'm off to Autozone for another one.
Old 03-01-05, 04:31 AM   #5 (permalink)
FIXER
Just put the third axle on the right side and test drove it. Finally, after 5 axle replacements in 7 days I have 2 good axles!
A rep from the company that overhauls the axles just called me(my neighbor is a director at Autozone) and we discussed the problems. He offered to send me 2 axles for my 94LS free. O-k. It has a torn boot on one side. Said he would hand pick the best ones...
The reason the ABS ring caused the ABS to activate was it was on crooked. One half of the ring would line up with the sensor, the other half would not, simulating a wheel lock up. This was hard to see with the axle installed, once removed it was obvious. Hope this helps someone in the future.
Old 03-10-05, 06:16 PM   #6 (permalink)
I just bought my 93 legend and I have a vibrating what I can't figure. At Park and N the car doesn't vibrate, but when I have it in drive with the pedal brakes applied i feel the vibration. A couple of times driving and i push on the gas to speed up I hear a rumbling. Can this be the axle?
anthony415 is offline   Reply With Quote
Old 03-10-05, 07:21 PM   #7 (permalink)
You could have damaged the wheel speed sensors while putting in the axles.
That or your fluid is low.
Old 03-10-05, 11:21 PM   #8 (permalink)
Car 1: Gynomobile
Volk Racing is offline   Reply With Quote
Old 03-11-05, 05:04 AM   #9 (permalink)
Originally Posted by VolkRacing
woops, maybe i should have read his posts
Old 03-11-05, 11:07 AM   #10 (permalink)
morbo's Avatar
Car 1: I35 Sedan
Car 2: 2004 Lincoln LS
Send a message via AIM to morbo
there's the problem right there! My understanding is that the Legend axles tend to wear away on the inner side, whereas most rebuilt or Aftermarket axles that are sold at auto parts store are remanufactured on the outside. I replaced my axels with a set from raxles.com about a year and a half ago with no problems. Raxles.com also come with a LIFETIME warranty-once they wear out you send them in and get new ones. I have been more than pleased with them!
http://ffejbomb.blogspot.com
CODEALARM CAR ALARM W/REMOTE START 4 SALE! PM OR EMAIL ME FOR INFO!!!
Keepin it real fo the SA
The Internet wasn't designed for ridicule. It was invented so researchers could share common data sets at University. It was I tell you.........it was. --Homer Simpson
morbo is offline   Reply With Quote
Old 02-23-06, 10:12 AM   #11 (permalink)
I had similar problem with my legend about 5 years ago when I got my axles replaced.
I've talked to Acura parts manager and he told me that refurbed axles are literally used axles with new lube and cover. I had mine replaced by midas and after replacing it, i had even worse wheel vibration. Midas told me that they replaced it, I asked them to take me under the car, I could grab the new axle and feel the movement. I told them this axle is bad, they said its good. So, I took it to the acura dealership in Cincy and they confirmed with me. Finally, Midas went thru 3 different sets to find one that was acceptable.
I don't know how things are now, but Acura 5 years ago Acura said there is no rebuilt kit for our axles. Best thing to do is make sure your CV boot isn't ripped and if its ripped, get it replaced asap. It will be cheaper as New axle from Acura (5 years ago) was $1500 each.
herblenny is offline   Reply With Quote
Oh crap ~ ABS parts!!! (90K checkup) FF Drifter Second Generation Legend (1991-1995) 1 01-03-04 09:05 AM
ABS kinda fidgity RangerJoe Second Generation Legend (1991-1995) 2 05-16-03 07:06 PM
First time at the track! theGodfather Track Racing 12 05-14-03 07:11 PM
89L model ABS sensor replacement Curious First Generation Legend (1986-1990) 0 09-29-02 12:10 PM
How to disable the ABS pump? 89 Legend VXi First Generation Legend (1986-1990) 3 09-12-02 02:39 AM
