Originally Posted by imjust2fast
Can you plzzzzzzzzzzzzzzzzzzzz tell me how you hooked up the fogs to the factory switch.
Sorry for the delay, FYI:
Please follow some threads that I found below, or do a search "fog light switch" under second generation Legend, you'll have a lot of related messages to read for days after days.
OEM fog light switch part #
https://www.acura-legend.com/vbulleti...&highlight=tcs
https://www.acura-legend.com/vbulleti...g+light+switch
Where to buy it from? Delray Acura.
http://www.acuraoemparts.com/delray/...1=&inputstate=
OEM fog light switch wiring diagram:
Assuming that you have a Hella Micro DE fog lights kit that come with prewiring harness including fog lights, relay, on/off switch, accessories and installation instruction.
How to use OEM switch instead of fancy hella on/off switch:
1. I went ahead and cut off the hella on/off switch wiring at the end of it (E) picture diagram, stripe off about 2" of insulation, then leave me three wires expose: Black, Yellow and Blue.
2. You can either solder or tap these 3 existing wires from hella on/off switch wirings to the new OEM fog light switch as follow:
Black -> Blue/Red (thick)
Yellow -> Blue/Red (thin)
Blue -> Blue/White
3. Don't forget to connect positive lug of hella wiring(usually red wire) to your positive battery terminal, negative lug to chassis ground (body frame) and splice or solder the blue wire (H) in picture to the corner light red wire (first bulb counts from the head light) too to feed the power from.
I wish I can remove my fog light switch one more time to take a real picture from behind to show you, but unfortunately there 2 very strong metal clips that hold the sw very tight, unless I have to break the inner tap one more time that I'm not willing to do it again which I did before.
Oh, you gotta drill a hole through fire wall to feed this on/off switch wiring control too.
Caution: this method apply for hella micro de only, other brands may have slightly different color codes, so use it as your guide line.
Good luck to you.
