Battery blew up. No damage - The Acura Legend & Acura RL Forum
Old 09-07-06, 11:08 PM   #1 (permalink)
FIXER
I drove home from work this morning(Night shifter) and stopped by my wifes coffee shop www.thecommongroundcoffee.com I went inside for about 10 minutes, came out and tried to start my 94Ls. When I turned the key to start I heard a loud "pop" and noticed smoke start to boil out from under the hood. I stared in disbelief and wondered where the closest fire extiguisher was. The smoke stopped after about 10 seconds and I got out and popped the hood. The only thing I noticed wrong was one of the battery caps was off and a little battery acid on top of the battery. I put the cap back on and got in and turned the key to "on", nothing, completly dead.
I drove the wifes car home, got some tools and a multimeter and drove back to the shop. I removed the battery and checked the voltage of it out of the car. 12.85 volts. hmmmmm. Was it the battery or something else? I had seen this before when I worked at Sears auto center battery department way back in 1985.
A battery can short out internally,. It will read good voltage with no load but die when loaded down. I took it to Autozone. It was a Duralast, 2yrs old with a 7 yr warranty. They put the tester on it and after about 5 secons of being under a load it dropped to 1 volt. I paid the $16 pro rate for the new battery and installed it in my car. With the new battery installed I started it up and checke the voltage. Alternator was charging perfect at 14.35 volts. I was concerned that the alternator was overcharging causing it to produce hydrogen gas thus causing the explosion. Everything checks good so I guess it was just a bad battery.
Old 09-08-06, 01:17 AM   #2 (permalink)
Textbook example of how to deal with and diagnose a problem. Well done, and hey! it coulda been a lot worse if battery acid had been dispersed to other areas of the engine bay.
Tinkindling is offline   Reply With Quote
Audio FAQ Johnny Kim Audio, Video, & Electronics 24 07-28-19 09:26 AM
anyone have a carfax subcription here? LGNDARY978 Second Generation Legend (1991-1995) 15 11-22-06 01:10 AM
Battery drain Netic First Generation Legend (1986-1990) 13 05-21-06 07:31 PM
Could someone please assist in obtaining carfax on this vehicle...seems 2good 2b true dreno74 Second Generation Legend (1991-1995) 14 02-04-05 02:59 PM
