A/C stuck on hot - The Acura Legend & Acura RL Forum
Old 09-18-08, 01:11 PM   #1 (permalink)
Car 1: 94 Acura Legend
A/C stuck on hot
My A/C is stuck on hot. pressure on the AC to make sure it was full and it is. So there is no leak. However when you manually open the AC control from behind the engine it will start to cool. Any ideas?
fernj is offline   Reply With Quote
Old 09-18-08, 01:45 PM   #2 (permalink)
ari_one's Avatar
Car 1: 1993 Legend 6-spd
Car 2: 2004 Tahoe
iTrader Score: 63 reviews
So are you saying your heater control lever is not working? It runs to the switch at the back of the engine, the silver box on the heater hose in pic below. If so check to make sure the cable is still in place.
https://www.acura-legend.com/vbulleti...-cloth-139765/
Old 09-18-08, 03:43 PM   #3 (permalink)
can you point out where the cable is. I cannot see it
Old 09-18-08, 03:47 PM   #4 (permalink)
iTrader Score: 24 reviews
there's also a motor under the pass side dash, its on the underside of the hvac assembly, it operates the switching from ac to heat. make sure its working, ac actuating when switched to ac from heat. if not, chances are u need a new hvac control unit.
Old 09-18-08, 05:38 PM   #5 (permalink)
ari_one's Avatar
Car 2: 2004 Tahoe
The cable should go from the firewall to the box attached to the heater hose. In the pic above you can see the large heater hose closest to the camera, it has a silver colored piece in the middle of the hose. The cable attaches to a lever on that box.
Old 09-25-08, 04:43 PM   #6 (permalink)
the cable is still connected to the heater hose. any other ideas.
Old 09-25-08, 10:10 PM   #7 (permalink)
ari_one's Avatar
Car 2: 2004 Tahoe
The cable should be connected to an arm that opens and closes the valve. Make sure that it moves to open and close when you adjust the heat.
Old 12-22-08, 12:20 PM   #8 (permalink)
Fixed **
The air Mix Control Motor was stuck. i loosed the wire a bit and gave it a little tap and it started working again. If the problem continues I will have to replace it but for now Its all good.
A/C stuck on hot-diagram.jpg
