Clunk sound from the rear - The Acura Legend & Acura RL Forum
Old 05-05-13, 10:41 PM   #1 (permalink)
Car 1: 1994 Legend GS Sedan (Japan) Sherwood Green Pearl
Clunk (hollow) sound from the rear
I am hearing a clunk (hollow) sound once in a while, from the rear while turning or going over the uneven road, SOME SPECIAL WAY. It sounds like the muffler is loose but I did checked the muffler pipes and rear suspension elements (to the best of my ability) under the car briefly, but nothing seems to be loose under there, apparently things looks tight.
I will remove every thing from the trunk, though nothing in there should be making that sound.
Thanks
94LegendGS4D78P is offline   Reply With Quote
Old 05-05-13, 11:51 PM   #2 (permalink)
Fut RIP
L3GDKANG/JDMKANG's Avatar
Car 2: 92 Alpha/ AlphaT KA8
Car 3: 91L,93LS,94LS KA7's
iTrader Score: 39 reviews
may be wheel bearing
Originally Posted by Blackend
Old 05-07-13, 05:26 PM   #3 (permalink)
BIGBOY's Avatar
Car 1: 94 acura legend ls
Sounds like your struts may be blown. I would also remove the rear speakers and look to see if every thing is tight.
Old 05-07-13, 08:56 PM   #4 (permalink)
Are u sure, wheel bearing can make such a sound? It almost sound like a drum.
Old 05-07-13, 09:19 PM   #5 (permalink)
I did checked the rear struts by pushing the car downwards from the back, seems OK, no abnormal sound. Will check speakers soon.
Thanks!
Old 05-08-13, 06:39 PM   #6 (permalink)
Car 1: 1993 Acura Legend Coupe, Auto
Car 2: 1998 Yamaha Yz 400f
Car 3: 2002 TTR125
prolly the lower portion of the rear sway bar links.its a bolt-thru -bushing design,rock the car by the roof left and right, have someone under the car looking at the lower part of the sway bar link and look for play at the end
93ledgcoop is offline   Reply With Quote
Old 05-15-13, 09:15 PM   #7 (permalink)
It mostly happening, during roundish left turn in a specific way. It sounds more like a drum, I was pretty sure that it has something to do with the exhaust pipes or muffler. I have gone under the car twice while jacked up and push and pull every possible thing including the sway bar, but nothing seems to make that noise.
I also pushed the car by the roof as you suggested, but was unable to reproduce that sound.
Old 05-15-13, 09:37 PM   #8 (permalink)
I did check the play in rear wheel bearing assemblies and found that there is a little extra play in the rear right passenger side wheel bearing. It knocks more than the left does, when push by both hands from 2 and 10 O'clock
But still not the sure the drum like sound should come from that.
Old 05-15-13, 11:29 PM   #9 (permalink)
Car 1: 93 Sdn
Car 2: 08 Sienna CE
It is very difficult just to replicate noises, particularly in front of a mechanic, so troubleshooting them on the WWW is an exercise in guessing. Now, the drumming wheel bearing scenario is possible. Turning left, the Pax rear tire has a wider radius pushing it to the outside, then when the car rolls straight the tire aligns. Then the wheel bearing cylinders almost instantly align or snap under pressure with the bearings spinning. Years ago I had some similar noises with another FWD auto.
Guario is offline   Reply With Quote
Old 05-15-13, 11:49 PM   #10 (permalink)
If you had the same drumming sound, then I take your analysis as the final answer.
Thanks and appreciated!
Old 05-16-13, 08:40 AM   #11 (permalink)
Car 1: 93 Sdn
Car 2: 08 Sienna CE
94Legd, it could be a failing wheel bearing, that is all I am trying to say. But as I stated in my first sentence, it is very hard to ascertain what causes an occasional noise in a car. It could also be a failing strut which suddenly extends, or a loose ball joint, also a deteriorated spring mount, among other things. However, if you have too much play in the wheel, probably the wheel bearing needs replacement. Hopefully that is the culprit, and it could be.
