Does your Legend crank but does not start? Here's a DIY diagnostic procedure - Page 8 - The Acura Legend & Acura RL Forum
Old 10-28-12, 09:08 PM   #106 (permalink)
Anyone know where I can buy a banjo bolt for the fuel filter.......other than a junkyard? Any info would be greatly appreciated.
me262 is offline   Reply With Quote
Old 08-03-13, 08:09 PM   #107 (permalink)
Scheibler's Avatar
Car 1: 93 Legend LS 6spd Coupe
Car 2: 02 CL-TypeS i/h/e
My legend is not getting fuel. Have replaced fuel pump and main relay! Wtf? Ignition seems fine
Scheibler is offline   Reply With Quote
Old 08-07-13, 06:04 PM   #108 (permalink)
Scheibler's Avatar
Found out my problem was the 7.5a main relay fuse in the kick panel along with a bad relay
Old 07-22-14, 01:46 AM   #109 (permalink)
Car 1: '91 KA8 L, Seattle Grey
I'm unsure whether this qualifies as a revs-but-doesn't-start issue, but I don't want to start another thread on a similar subject, so I'll try posting about it here first
For about 2 weeks now, when I turn the ignition, my Legend will simply rev low and not start without repeated (around a dozen) very fast pumps of the throttle and one to get the engine going strong which, as we all know with our cars, should not be the case. This must be done nearly every time I start the car, sometimes not, if it's only been off for a few minutes. I've resoldered my EMI, checked the pulse of my injectors, checked for fuel pressure, changed my plugs and checked my coil packs... Before I continue scratching my head and go down the list of shit in the original post I thought I'd post about me just in case someone has an idea as to why this might be happening, and how to go about fixing it
deadmanepoxy is offline   Reply With Quote
Old 10-03-17, 04:13 AM   #110 (permalink)
Car 1: Acura
test car's pump
trungtamxetaisg is offline   Reply With Quote
Old 08-21-20, 03:51 AM   #111 (permalink)
1995 Legend Sedan SE with automatic transmission. Was out shopping, came out to the car and it would crank but not start. Had it towed home. Thought maybe it was the high heat and humidity. Went out next day and it started right up. Drove it all day and I had one minor glitch. When the car was idling, motor just shut off. Cranked it right up, started and ran fine the rest of the day. Next day (this evening) it cranks but does not start. Nothing different with the lights in the dash. Does the computer control spark on this? Where would I look for this as it seemed to have fixed itself, and now the problem came back.
Dana M W is offline   Reply With Quote
Old 08-21-20, 01:11 PM   #112 (permalink)
Legend32's Avatar
Car 1: Honda Legend Coupé 91
I also rarely had the problem with cranking without starting. i knew about the main relay and so i looked at it.
i found some cold solder joints, if that is the correct term.
Of course I re-soldered them and so far I have no more problems. I think, that's the first thing you can do easily.
Greetings
Ralph
Honda Legend Sedan '90 - Sold
Honda Legend Coupé '91
Legend32 is offline   Reply With Quote
Old 08-21-20, 09:56 PM   #113 (permalink)
Okay, I will try what you say here. Today, I took it out and soldered the two areas that needed it. Now everything is fine. Back to normal...
crank angle sensor diy maytagman First Generation Legend (1986-1990) 5 02-29-08 08:34 PM
Thinking about TB just for PM but would be nice to find DIY procedure here FiveSpeed Second Generation Legend (1991-1995) 8 02-11-07 06:55 PM
DIY: A/C Compressor Rebuild Procedure w/pics DallasLedge89 First Generation Legend (1986-1990) 5 12-30-06 11:33 PM
Noisy HLA's: Causes and Diagnostic Procedure Cruz'nLegend First Generation Legend (1986-1990) 3 06-20-05 01:26 PM
long crank to start ZiGGie Second Generation Legend (1991-1995) 8 06-07-03 07:18 AM
