Emergency Brake Adjustment - The Acura Legend & Acura RL Forum
Old 09-26-06, 05:32 PM   #1 (permalink)
Are there any DIY's on adjusting the emergency hand brake? Is it easy enough to do?
LALEGENDGUY is offline   Reply With Quote
Old 09-26-06, 11:29 PM   #2 (permalink)
It is very simple to do by yourself. The e-break is a drum break that operates on the rear wheels. It is completely separate from the disk break system. This is how you adjust it.
1. Jack up car and put on stand (do not leave on jack, this is dangerous!).
2. Remove the wheel.
3. Remove the little rubber cover on the wheel hub (Black and about the size of a nickel).
4. Use a flashlight to look inside the little hole, you will see a sprocket w/ little teeth on it.
5. W/ the e-break completely released, spin the wheel hub while adjusting the sprocket with a flat tip screwdriver. I think up is tighten, down is loosen but you get the idea.
6. When the hub just barely begins to drag when you spin it, back it off a notch and you are done.
8. Replace the little rubber cover. (you may not have this, mechanics don't really care about replacing them if you ever had the breaks done somewhere as they're not really necessary).
7. Proceed to the next wheel and repeat.
When you are done it should take about 4 clicks of the e-break to set it securely. If you are in doubt about the amount of "meat" left on your pads, you can take the hub off and look at them, but it really shouldn't be an issue unless they were abused/mal-adjusted previously.
-Tim
TLReaves is offline   Reply With Quote
Old 09-27-06, 12:19 AM   #3 (permalink)
Car 1: 91L 5spd blue cpe
Car 2: 92LS 5spd gray cpe
Car 3: 93LS 6spdgraycpe 3.5
Very nice and concise Tl; Thank you. LALEGENDGUY: did that address your
concern? I have never had a hand brake issue in 260,000 miles over 15 years.
What prompted the question: warning light? rolling car? Inquiring minds want to know. Thanks.
Old 09-27-06, 12:21 AM   #4 (permalink)
Dont Catch
bl420's Avatar
Car 1: 92 Integra
iTrader Score: 16 reviews
sometimes when its worn down a bit... the parking brake pads might not have enough bite on the hubs
for example if you hear too many clicks before the pads have enough pressure on the hubs.
**Anti Alpine Type-R Thread**
Old 09-27-06, 12:27 AM   #5 (permalink)
MAN-WHORE
KINGFABIAN's Avatar
Car 1: 1994 Legend Sedan L 2005 Infiniti QX56
You can also adjust the ebrake at the handle inside the car. If you take that middle console off youll see an adjustment screw at the base of the E brake handle as well
King of the Bling & Lord of the Blang!
KINGFABIAN is offline   Reply With Quote
Old 09-27-06, 12:37 PM   #6 (permalink)
What Prompted the Question
Well, when I pull on the e-brake it pulls all the way upward very easily and quickly, and i noticed the car still rolls. This is when I realized my e-brake is not adjusted properly. Can it be something else?
Old 09-27-06, 12:45 PM   #7 (permalink)
It is the e-break out of adjustment. Should take about 4 clicks to set which is like 25-30% of the total throw the break can handle. They probably just haven't been adjusted in a while. Adjust it first and then inspect the e-break cable to make sure it is intact. I'm confident this will fix your problem.
Old 09-27-06, 01:19 PM   #8 (permalink)
Okay thanks. I read Kingfabian's suggestion to adjust the e-brake from inside the counsel where the hand brake is located. Does adjusting the brake from either inside the or the wheels have the same result?
Old 09-27-06, 01:38 PM   #9 (permalink)
I have never adjusted from the inside so I can't really speak to that. What I can say is that what you are adjusting from the console is just the tension/length of the cable, whereas when you take the wheel off and use the sprocket approach you are physically moving the pads closer to the drum, so they don't have to move as far. That is just the way I was taught to adjust drums/e-breaks.
Old 09-27-06, 02:07 PM   #10 (permalink)
S4gunn's Avatar
Car 1: 02 Audi S4
Car 2: 97 Honda Accord SE
My understanding is that the adjustment of the cable from inside the car is for a minor adjustment and the adjustment of the cable from outside is a "major" adjustment.
From my experience: If you have to pull the e-Brake up all the way and it still rolls, you won't pull enough slack by doing the minor (in car) adjustment. Get the jack out - it's a pretty easy job.
2002 Audi S4
S4gunn is offline   Reply With Quote
Old 09-27-06, 09:14 PM   #11 (permalink)
The Crowing's Avatar
Car 1: 1991 Legend Coupe LS
Mine was slack and the in-car djustment worked fone for me. Just watch out for the airbag wires. Airbag systems terrify me. >.<
The Crowing is offline   Reply With Quote
Old 09-27-06, 10:13 PM   #12 (permalink)
hey i kinda have the same problem so im going to check this out... but i hjave a question, my E brake light is on when it is down. any ideas?
eddie101 is offline   Reply With Quote
Old 09-27-06, 11:24 PM   #13 (permalink)
If the break light is on you need to check the break fluid for the disk breaks and make sure it is full.
Old 09-28-06, 03:05 PM   #14 (permalink)
T The pimp
truonghthe's Avatar
Car 2: 93 Legend L AT
Car 3: 92Legend L AT R.I.P
i just adjust my since i slap in a new set of rotor from brembo. now it perfect.
In memory of 92 LS 5spd
"I AM LEGEND"
To This
truonghthe is offline   Reply With Quote
G1: Disc Brake Pad and Rotor Replacement DIY (Photos) body9599 DIYs 12 08-31-09 06:32 PM
Disc Brake Pad and Rotor Replacement DIY (Photos) body9599 First Generation Legend (1986-1990) 7 04-30-09 02:31 PM
ABS Light and Brake Master Cylinder PA_Legend Second Generation Legend (1991-1995) 7 12-08-04 05:48 PM
Emergency Brake Shoe asianlegend Second Generation Legend (1991-1995) 12 05-13-03 10:25 PM
Emergency brake doesn't work why? CBRKid20 Second Generation Legend (1991-1995) 13 11-07-02 11:56 PM
