idle problem - The Acura Legend & Acura RL Forum
Old 01-31-06, 09:54 PM   #1 (permalink)
idle problem
92 acura legend 4dr,runs great, but once it warms up it stalls?? starts right back up, but u have to keep my foot on the gas, whats up??
carcrazeeeee is offline   Reply With Quote
Old 01-31-06, 10:50 PM   #2 (permalink)
Car 2: 1999 Acura 3.5RL
Car 3: 2004 GMC Sierra Z71
Sounds like an idle air control valve (IACV) or the Throttle position sensor (TPS).
check it for codes first: https://www.acura-legend.com/vbulleti...&threadid=1972
See my answers on the diagnosis of the TPS here: https://www.acura-legend.com/vbulleti...osition+sensor
You can clean the throttle body by following this thread: https://www.acura-legend.com/vbulleti...highlight=idle
I can post instructions on diagnosing the IACV tomorrow if you want. Where are you in Ohio? You wouldn't happen to have a champaigne sedan do you?
Old 01-31-06, 11:05 PM   #3 (permalink)
swift's Avatar
Car 1: 92' C35 KA8 5spd
Car 2: 92' Ka8 5spd turbo
mike,
I was fiddling around today and made it so my VIS was working fully again so i was tinkering with some other vacuum lines and have some questions
CAn i disable PAIR?
and i disable the vacuum line on top of the fuel regulator...and it brought up idle slightly. The reason i did this was before with VIS and manifold pressure. I would think that i am getting better fuel/air low end and top end is the same. Drove home tonight and seemed good.
sorry for hijack...thought it was releavant.
215whp+
Old 01-31-06, 11:19 PM   #4 (permalink)
idle problem
im in col ohio, sorrry, ive got a greyish sedan. it just started doing this no idle when it warms up thing. it stays up at high idle when u first start it up, but when u come to a stop, i have to put it in netureal and keep my foot slightly on the gas, it sucks!!!
Old 02-01-06, 12:03 PM   #5 (permalink)
check those threads I linked you to earlier. One of those will solve your problem.
Idle Problem bee-stro Second Generation Legend (1991-1995) 5 06-14-05 12:29 AM
Idle problem solved, stupid me!! fattypanda Second Generation Legend (1991-1995) 9 10-14-04 10:36 PM
Idle prob, I know it's been beaten to death jcbmrtn Second Generation Legend (1991-1995) 54 10-01-04 12:51 AM
Surging idle problem.... Sean L Second Generation Legend (1991-1995) 2 11-04-02 11:36 AM
Cold Start Idle? DaTimez420 Second Generation Legend (1991-1995) 2 03-18-02 01:04 PM
