Offset Question - The Acura Legend & Acura RL Forum
Old 02-11-02, 09:12 AM   #1 (permalink)
Question Offset Question
What's the best offset for the Legend?
18x7.5J offset available: 30/43/55.
18x8.0J offset available: 24/37/49/62
18x8.5J offset available: 18/30/43/55/68
18x9.0J offset available: 11/24/37/49/62/75
18x9.5J offset available: 5/18/30/43/55/68
18x10J offset available: -1/11/24/37/49/62
Is it 18x7.5 43 offset?
MC® is offline   Reply With Quote
Old 02-11-02, 09:58 AM   #2 (permalink)
*r**h *eller
Car 1: 07 TSX
Car 2: 08 Odyssey
Car 3: The roller skate
GO FOR THE +55 ON 18x7.5.
I like my little red roller skate.
Dave C ver2.0 is offline   Reply With Quote
Old 02-11-02, 01:01 PM   #3 (permalink)
Dave,
Just in case I ever wanted to sell these will +55 limit the amount of cars these will fit on?
Would +43 cause rubbing or fittment problems?
Thanks, again.
Old 02-11-02, 01:08 PM   #4 (permalink)
Car 1: 2010 TL SH-AWD 1994 LS Coupe
Car 2: 1999 VIP Lexus GS400
Car 3: 1991 CRXsi 2010 Rav4
iTrader Score: 6 reviews
Send a message via AIM to TYPEII
Originally posted by MC_
Dave,
Thanks, again.
Nope, they can always add spacers to the +55 wheel.
+43 offset is not a problem as long as you run 225-40 tires.
94 Coupe LS-Taffeta White
19" Racing Hart C2 19 x 7.5 +45 offset Falken Ziex 502 235-35-19
Carbon Fiber Hood from Japan
JDM 1-Piece Headlight with Audi A6 HID projectors and 6000K Philips Ultinons
Sound system: Pioneer AVIC-N1, Pioneer XDV-P90 DVD changer, JL Audio 12W7, JL Audio 1000/1,
Soundstream Reference 604, MB Quart, Diamond Audio
Eibach and Konis, Greddy Exhaust, Mugen Pedals, 2-Tone Leather—Plus, tons more...
TYPEII is offline   Reply With Quote
Old 02-11-02, 01:39 PM   #5 (permalink)
I just want to confirm that it is OK.
Alexander is offline   Reply With Quote
Old 02-11-02, 03:22 PM   #6 (permalink)
Guest
Posts: n/a
Question TYPEII
How about 18X7.0 with a +40 offset? would it rub on a G2 Coupe?
I want 225/40/18 rubbers... I think with the 7.0 it would be tucked in the wheel well even with the +40 offset... Anyone think otherwise??
Old 02-11-02, 03:57 PM   #7 (permalink)
I think it should be fine, but I just not comfortable on putting 225/40R18 tires on 7" wide rims. But it should be OK, no safety concern here, just looks I guess.
Old 02-11-02, 04:15 PM   #8 (permalink)
Guest
Posts: n/a
Question Alexander
Why how would it look??? would you suggest 215/40?? and why?
Old 02-11-02, 04:45 PM   #9 (permalink)
Re: TYPEII
I would go with the 225-40 tires. That way you would have extra rubbers to protect the rim lip.
When I had my SSR DeColte that's what I did - 18 x 7 with a +49 offset.
You can see picts of them on Darren's car (Acuralegend.com)
http://www.onlineshowoff.com/index.a...le&username=dk
Old 02-11-02, 04:47 PM   #10 (permalink)
I think it will fit, if I can run 19 x 8 with a +51 offset and 235-tires than that setup should not be a problem.
My setup is bigger and I get no rubbing at all, plus I have Koni and Eibachs.
Old 02-11-02, 06:44 PM   #11 (permalink)
Almost the same here, hehehee........... the older version, the notorious C5, hehehee..........
Old 02-11-02, 07:44 PM   #12 (permalink)
Five- O
Esti's Avatar
Car 1: 88 L Coupe 5 Speed
please help a g1 owner !!!!
Maybe some you g2 owner's who used to own a g1 can help me with my offset problem !!!! Please!!!!!!!!!!!
I currently have borbet type S rims which are 17 X 7.5- I Believe that the offset is 35. I'm sure of the offset b/c i saw the info on a site and it stated [ 17 X 7.5 ET 35].
So here are my questions is the ET the offset?
If not then where can I find out what is the offset for my rims?
I ordered them from Tire rack. Will they be able to give me the info?
The reason i want to know the offset is b/c I plan on lowering my g1 coupe (eibach/tokico) and want to know if i will have a rubbing problem.
If 35 is the offset will I have rubbing probelm after I lower the car.
Please help !!!!!!!!!!
Thanks
Esti
88 Coupe L 5- speed
Weapon R Intake
17 inch Borbet type S [Summer months]
Stromung exhuast Cat-Back
DEC Hi-Flow Cat
90 tail Lights
Cross drilled rotors
Eibach Springs/KYB Shocks
APC Sway Bar
Esti is offline   Reply With Quote
Old 02-11-02, 11:07 PM   #13 (permalink)
0000$$$$0000####0000
Car 1: Acura
I'm with Dave. Get the 18X8 or 18X7.5 with the +55. While rubbing may not by an issue with the lower offsets, you will defiantely stick out in front if you have 0 degree camber with anything lower than a +48. I base this on my 17 X 7 with +46 rims, With 0 degree front camber, my front rims stick out about 2 mm or so. It is not much, and a very slight .5 degree negetive camber tucks it in nicely, but stil, it will stick out if the conditions are right. And I only have a 7" wide rim with a +46mm offset.
Now keep in mind, my firend actually has a 17 X 7 with a +38 offest. With 0 degree camberm, the front rims used to stick out about 4 mm or so. Also note, his 7" rim has a total width of 200mm, while my 7" rims has a total width of 202mm. With 215/45 ties on his car, lowered about 1.75" with Eibachs and konis on low, and corected camber to about .5-.7 negetive, his front tires are perfectly flush with the outer lip of the fender, and he does not rub at all. So, how you set up your front suspention like camber and ride hieght will determine how low an offset you can get away with. Also the total width of the rim will also play a factor. The 7" designation are all standard for the measurement of where the tire bed is, but the over all width depends on the rim design. Just as my friends 7" rim has a total of 200mm, and offset of +38, and mine has a 202 total and +46, the offsets are only reletive to our own rims. As If he had a 200mm rim with an offset of +46, he would essentially have a more positive offset than I do with my 202mm +46. For example, a +50 on a 200mm rim would have 100mm on each side. A +50 on a 202mm rim would have 101mm on each side. You have an extra 1mm sticking out on each side of the rim, and that 1mm could determine of you just clear, or barely rub.
ChrisK is offline   Reply With Quote
Old 02-11-02, 11:15 PM   #14 (permalink)
Guest
Posts: n/a
Question ChrisK
So if I want to run 18X7.0 w/ a +40 offset can I go with a 225/40/18 or would I be better off with 215/40/18 because I want to lower the car on koni's and eibach's?
Old 02-12-02, 09:33 AM   #15 (permalink)
502MotorSports.com
502 MotorSports's Avatar
Car 2: e60 530i | e46 330i
Car 3: S430
Re: ChrisK
I would suggest the 215 vs the 225 on a +40mm offset.
Here is mine before, with 225/40/18 with 40mm offset, 18x7.0
In this setup, it didn't scrub, but the 225 tire would be flush with the fender, with more - camber. This is lowered 2" up front
502 MotorSports is offline   Reply With Quote
