OK everyone with SLOOWWWW windows read this - Page 4 - The Acura Legend & Acura RL Forum
Old 06-18-09, 04:38 PM   #46 (permalink)
Usually lurking
Wendigo Redux's Avatar
Car 1: 1990 Legend L Sedan
This is an old post, but I want to let you guys know how much work this post saved me. l was prepared to go to work on the window regulator since I had lubricated the tracks to no avail. I bought the Shin-Etsu after reading this as a last ditch effort to fix the passenger window and it was amazing how using the correct lubricant fixed it miraculously.
This saved me a ton of work. If anyone has slow windows, or even if you don't, get some Shin-Etsu becasue you are going to need it. Since we have several Hondas, I bought a couple tubes but a little goes a LONG way. Thanks guys.
Wendigo Redux is offline   Reply With Quote
Old 06-18-09, 06:02 PM   #47 (permalink)
Car 1: 1995 Acura Legend GS
iTrader Score: 4 reviews
Glad I could help, its been over a year now sense I first added it and mine still roll up fast and smooth!
174,000
My ride
Roger is offline   Reply With Quote
Old 06-29-09, 02:24 AM   #48 (permalink)
Car 1: 1994 Acura Legend
Good call bro!
I wish I would have read this post before I replaced my regulator and rubber seal. For some reason, it only slows down sometimes. Other times its fine. ?
mister310 is offline   Reply With Quote
Old 06-29-09, 04:00 AM   #49 (permalink)
Car 1: 91 LS Sedan
Originally Posted by dgandul View Post
crc can of silicone from walmart for 3 dollars.... works for like months. i think the last time i did it was in january and its still good.. but we dont get harsh weather down here so i dont know.
Yep, Big red can of silicone spray. Works great on everything!
Conrad is offline   Reply With Quote
Old 06-29-09, 06:58 AM   #50 (permalink)
Months verses years humm I would go with the Honda stuff, spray silicon is going to dry out your channels overtime
174,000
My ride
Old 06-29-09, 11:34 PM   #51 (permalink)
customLegend91's Avatar
Car 1: 1991 acura legend sedan ls
Car 2: 1997 civic coupe
Car 3: 1997 civic hx coupe
Originally Posted by Roger View Post
OK so my windows have always been kinda slow and crappy always sounded like the motor was about to die and when it was raining forget it I had to pull it up with my hand. I always thought the regulator was bad like everyone says, so the other day i took my door apart, took the regulator out and looked it over. Looks great a little dry but no broken or bent parts, so I lubed up the regulator tracks and gear with Lithium grease no improvement. Then I did something stupid and tried to put the lithium grease in the rubber channels that the window slides in. It worked great for a day then was way worse, not to mention lithium grease is petroleum based and will eat your rubber.
Then I found the real cure, I did some research and for a special lube called Shin-Etsu It is a special very low viscosity silicone lube. This stuff is only available from your Honda dealership and is what they use on all there seals. This stuff is truly amazing I cleaned my channels out got rid of all that lithium grease and put this in. WOW my windows now slide up and down effortlessly seriously like butter, my windows have never worked so well. Now ive only been using a few days so I cant testify on the longevity of the cure but from my research it will last for a long time and is very easy to re apply. This stuff can also be used on all your seals and will help extend the life of all your door seals. Its alittle pricey at 20$ a tube but it is well worth it for all you will slowww rolling windows try it out.
Bought it here
HONDA-ACCESSORIES.COM
lol i did something very similar (Vaseline) worked good for five min
i used a silicone spray lube i picked up at my local autoparts store (kragen)
i believe it was 3.99 not shure tho i did this 4 months ago and my windows still work perfect i would recommend doing the lubing twice a year or as needed depending on the condition of your rubber
customLegend91 is offline   Reply With Quote
Old 08-15-09, 01:28 AM   #52 (permalink)
OLDSKOOLACURA's Avatar
Car 1: 93 ACURA LEGEND LS
Car 2: 2006 KAWI 636
Car 3: 2004 KAWI 636
i used WHITE litheum grease and it worked good to, might have to try the Shin-Etsu stuff
OLDSKOOLACURA is offline   Reply With Quote
Old 08-16-09, 07:16 PM   #53 (permalink)
Car 1: 1993 Acura Legend
tracking
Start Fast Finish Strong!!!!!!!!!!!!!
Hugo M. Rivas is offline   Reply With Quote
Old 08-16-09, 09:19 PM   #54 (permalink)
tracking what?? its a done deal you should not be using anything else on your window channels besides this Shin-Etsu.
174,000
My ride
Old 08-16-09, 11:26 PM   #55 (permalink)
czechboy's Avatar
Car 1: 1994 Acura Legend GS
Send a message via AIM to czechboy
I went out and got the grease and used it yesterday. My windows go up a lot faster now and it doesn't sound like the motor is struggling anymore.
czechboy is offline   Reply With Quote
Old 08-17-09, 04:52 AM   #56 (permalink)
Uni-Versal's Avatar
Car 1: 91 Silver Steel KA8 LS
Send a message via AIM to Uni-Versal
Great thread. Thanks alot! Will def try this out!!!!
Ever see a Legend driving a Legend?
Legend Coupe Ressurection coming sooner than you think...
Uni-Versal is offline   Reply With Quote
Old 08-17-09, 06:46 AM   #57 (permalink)
Yup exactly my results, its like double the speed and no more motor groan half way through
174,000
My ride
Old 08-20-09, 02:15 PM   #58 (permalink)
93LC's Avatar
Car 1: '93 Legend Coupe
Car 2: '03 MDX
Last mod b4 I sell it...
93LC is offline   Reply With Quote
Old 08-27-09, 03:31 PM   #59 (permalink)
95typeII's Avatar
Car 1: '95 Legend Coupe LS
I recently bought some Shin-Etzu silicone grease from the local dealership for $19. When I removed the door panel, i noticed the window was going slow because part of the run channel seal was pinched between the glass and rail. I fixed it and greased up the channels and the window now rolls up & down with ease.
95typeII is offline   Reply With Quote
Old 12-23-10, 02:27 PM   #60 (permalink)
Car 1: 1991 Legend L Sedan Wrecked!
Car 2: 95 Legend "L" Sedan
I applied a lubricant called Sil Glyde from Napa. This is a multi purpose silicon lube used on brake calipers and window seals. Cost in Hawaii is $6.49 for a 4oz tube. Cheaper than Shin Etsu but will see how long it holds up.
91boz
91boz is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
goldey
