Radiator Cap Pressure. - The Acura Legend & Acura RL Forum
Old 10-04-20, 04:12 AM   #1 (permalink)
Underthebluesky's Avatar
Car 1: 1993 Honda Legend Coupe.
Hello again.
Today my bottom hose decided to pop off from the engine side. But before that happened, I replaced the radiator cap. The cap is rated at 1.3 bars. The coolant level in the overflow tank prior to this ordeal was just a finger width above max. Coolant does not spill out of the overflow tank.
Driving to a nearby park for a leisurely stroll posed no problems.
However, the journey home was when it happened.
In both situations I drove leisurely.
If my memory serves me right, the specifications of the radiator cap should be between 1.1-1.3 bar.
I also replaced the radiator, top and bottom hoses the thermostat and coolant half a year ago, however didn't replace the hose clamps.
I never had a problem with the bottom hose popping out until today.
So what I'm wondering is...
Who's the culprit here? The new cap or the old clamps? Or both?
Also, while I have your attention, there's a minor leak at the thermostat housing. The housing itself seems fine. Could it be the gasket wasn't seated in properly? I only noticed this recently. It likely has been going on for a period of time, judging by a couple of dried stains.
Good day.
Underthebluesky is offline   Reply With Quote
Old 10-04-20, 04:45 AM   #2 (permalink)
Hello again.
It seems like I made a mistake when choosing radiator caps.
The rating range is 0.95 - 1.25 bar, and not 1.1-1.3 bar as I had previously thought.
Perhaps this rise in rating is the culprit.
Higher rating = higher boiling temperature, which in my mind means the coolant is allowed to get hotter before it reaches boiling temperature and so there is more pressure?
I guess what I'm trying to ask is: does a higher-rated radiator cap increase coolant temperature and/or pressure, or does a higher-rated radiator cap allow more wriggle room for the engine because it increases boiling temperatures?
Good day.
Old 10-05-20, 01:46 AM   #3 (permalink)
Hello again,
I've just replaced the coolant and the coolant clamps. I've reinstalled the thermostat. I've also bled the system.
The original radiator cap was put back on.
So far I don't see any leaks from the thermostat housing. Nor from the radiator.
However, there's this rhythmic sound, and I think it's coming from the front of the engine.
Here's a video of the rhythmic sound.
https://photos.app.goo.gl/wSpFbPj7nuAadEEM9
Last oil check was last week. No top up was necessary.
Good day.
Old 10-05-20, 02:56 AM   #4 (permalink)
Hello again.
I've just went for a test drive.
Most of the spilt coolant has been evaporated. At the same time, the sound I described in the above post has all but subsided as well, so perhaps it was something to do with that.
No leaks reported.
Good day.
