-   -   Rims (https://www.acura-legend.com/vbulletin/showthread.php?t=118433)
Blackend 02-27-08 09:53 PM
Originally Posted by C32A5 (Post 1226537)
As a side note, what is the stock offset for our cars?
55
7.5" = 45 or higher
8" = 50 or higher
The Crowing 02-27-08 10:18 PM
^Appreciated, thank you. What the downside to using a lower offset? And that avvie is worse than the damn hyena! >.<
Blackend 02-27-08 10:25 PM
LOL - every couple of days I google "bad pictures" and find a new avatar :D
The downside to a lower offset is the rims sticking outside of the top of the fenders. The offsets above that I listed are the generally agreed upon maximum's that you'd want to run on a Legend (maximum being the lowest number you'd want) so anything with a higher number should be fine.
Basically, how it breaks down is the Legend hub's are really far outside the centerline of the car, so we require a higher offset (spacing from the hub face to the centerline of the rim) in order to keep the rubber under the car and not beside it.
Here is a good article on tirerack.com about offset that helped me understand what the numbers mean.
The Crowing 02-28-08 12:16 AM
^Thanks! Maybe I will get some chrome flares, yo! (Kidding...)
