stock radio code won't work- - The Acura Legend & Acura RL Forum
Old 05-27-09, 02:57 PM   #1 (permalink)
So after the bhg job, i've got my battery back in but the radio needs a code. I found the code with the serial number on a card. I pulled the radio to make sure the serial numbers matched and they do. However, the code does not work. I put the 6 digit code in several times but to no avail. Any ideas?
fforge44 is offline   Reply With Quote
Old 05-27-09, 03:00 PM   #2 (permalink)
oops I meant to say 5 digit code.
Old 05-27-09, 03:23 PM   #3 (permalink)
Chopper Challenge Champion
iTrader Score: 6 reviews
Did you put the code in slowly? Press button, pause for a second, press next button, pause for a second, etc. If you try to punch in the code too quickly, it sometimes misses a number or two.
If you tried too many times and failed, you'll have to pull the battery power and wait a few minutes because the radio will lock itself down after too many failed attempts.
Banana! is offline   Reply With Quote
Old 05-27-09, 03:31 PM   #4 (permalink)
ha! yep, i just got finished trying that and it worked. solved my own problem before i got a reply, but thanks! your info was exactly right.
