Stripped Head on Oil Drain Plug - The Acura Legend & Acura RL Forum
Old 03-25-06, 08:55 PM   #1 (permalink)
Car 1: 1991 Blue Sedan
Send a message via AIM to abcheng
I was trying to change my oil today, but the head on my oil drain plug is partially stripped and I think this was due to a POS socket and the fact that it cracked. What can I do to get the plug out?
abcheng is offline   Reply With Quote
Old 03-25-06, 08:58 PM   #2 (permalink)
Dont Catch
bl420's Avatar
Car 1: 92 Integra
iTrader Score: 16 reviews
a bolt extractor
**Anti Alpine Type-R Thread**
Old 03-25-06, 09:20 PM   #3 (permalink)
er... serious? If so, where can I get one?
Old 03-25-06, 09:54 PM   #4 (permalink)
Type I King
Car 1: 92 LS Sedan
Car 2: 91 LS Coupe 5 spd
Car 3: 95 LS 6 spd coupe
iTrader Score: 7 reviews
sears has em.
Old 03-25-06, 10:15 PM   #5 (permalink)
Something like this? http://www.sears.com/sr/javasr/produ...+Taps+%26+Dies
Old 03-25-06, 11:13 PM   #6 (permalink)
Dont Catch
bl420's Avatar
Car 1: 92 Integra
nut or bolt remover...
http://www.sears.com/sr/javasr/produ...id=00952160000
Old 03-25-06, 11:52 PM   #7 (permalink)
what!
kotetu's Avatar
Car 1: 95 LS Coupe 6 spd
Car 2: 02 TT225 Quattro 6sp
Car 3: 94 L Cpe 6spd - sold
iTrader Score: 20 reviews
could also try a "gator grip" socket. Those work pretty well.
http://gator-grip.com/
Stephen Ballachey, March 17, 2006
Dear Mike: I just wanted to drop you a note to thank your for this marvelous socket. I recently purchased a vintage VW for restoration and was having a tough time removing rusted in body bolts; many of which had been eaten half through by unchecked rust and negligence. My traditional sockets couldn't remove the "rounded heads" of these bolts. Then I discovered your product at the local hardware store. It worked like a charm! One by one my Gator Grip socket popped those bolts free and, after a week of busted knuckles and cursing I can tell you I am one happy VW owner now! Thanks again for your invention. It saved my bacon. ;-)
kotetu is offline   Reply With Quote
Old 03-26-06, 12:17 AM   #8 (permalink)
Thanks for the responses, the Craftsman Bolt- Out tool and the Gator Grip both like they could work. I'll go to Sears and pick up something that'll hopefully work.
Old 03-26-06, 07:13 PM   #9 (permalink)
If not there's always a left hand drill bit haha. But you wanna avoid those.
Mikey851 is offline   Reply With Quote
Old 03-26-06, 09:38 PM   #10 (permalink)
iTrader Score: 15 reviews
flare wrench.
vise grips.
force a smalled socket on by banging it and then turn it.
disclaimer: i have fucked up many things and dont really know what i am talking about.
quanaman is offline   Reply With Quote
Old 03-27-06, 12:51 PM   #11 (permalink)
Pre**y Boy
Car 1: 94 legend LS 4Dr
Just to post a stupid comment, but lets face it, there are some questionable people out there. Please get a new bolt and don't put the old one back on when you are done with the oil change. Just a suggestion.
"Sex is like pizza, even when it's bad it's still pretty good."
kirky40 is offline   Reply With Quote
Old 03-27-06, 01:58 PM   #12 (permalink)
I never said I wasn't gonna get a new bolt . I'm ordering one, but I need to get the partially stripped bolt out first right?
Old 03-27-06, 03:09 PM   #13 (permalink)
yep u should
hondacrazyhonda is offline   Reply With Quote
Old 03-27-06, 03:31 PM   #14 (permalink)
iTrader Score: 24 reviews
yeah a vise grip should work, also remember that the old pan bolt should not be put on with more then about 20ft-lbs of torque... you should not even need a ratchet to take it off, a closed end wrench is the only thing you should use. also if you are going to be using a ratchet use a 6 point socket. but don't tighten the bolt past 20ftlbs
Old 08-27-06, 08:26 PM   #15 (permalink)
The oversized oil pan plug worked like a charm. Thanks guys...!!!
Big Dre' is offline   Reply With Quote
Radiator drain plug Acurately Legendery First Generation Legend (1986-1990) 6 05-15-05 07:45 PM
Drain Plug Oil Leak OrionZite First Generation Legend (1986-1990) 24 05-27-03 03:16 AM
Engine oil Bolt size// Drain hole Gold Second Generation Legend (1991-1995) 4 09-24-02 09:09 AM
Oil Pressure drop big time flashdragoon First Generation Legend (1986-1990) 7 05-11-02 01:38 PM
