Timing Belt Help..... - The Acura Legend & Acura RL Forum
Old 05-28-05, 10:13 PM   #1 (permalink)
Car 1: 92' White Sedan
Send a message via AIM to knucks3man
lol these topics are all over the place.
But I'm doing my own timing belt, cars at 140 thousand and still has original...
Heres the situation, looking at engine from front of car.
When I turn the crankshaft so that the white mark lines with the lower cover mark, the left cam mark (red) is maybe one tooth past the yellow marking.
At this same point, the right cam mark is dead on the yellow.
Is this normal?.....(Cam nor the Crank have been moved since belt removed)
I figured is was, I went ahead and kept working and am down to the waterpump removal....I have all bolts out, but it looks like the wp is behind the right cam and right cam bracket. (the metal behind cam gear)
Does the Cam gear and the metal bracket peice need to be removed?
THNX FOR ALL HELP IN ADVANCE......Hopefully it all works out for me.
knucks3man is offline   Reply With Quote
Old 05-28-05, 11:30 PM   #2 (permalink)
AKA Smartjay28
Johnny Kim's Avatar
Car 1: JDM KA7
Car 2: w203
right cam->
-pointer on the cover plate (yellow) line up with TDC(top dead center) red
Left cam->
-pointer on the cover plate (yello) line up with TDC Blue
drive pulley->
-pointer on da oil pumps lines up with key way mark on da pully.
when i was gettin my car done, mine skipped 2 teeth.
good luck.
Old 05-28-05, 11:37 PM   #3 (permalink)
I am looking at the engine from the front, standing in front of car.
So your right cam is my left and vice versa.
I only have a red mark on the left cam and two blue ones on the right. I think it is ok because nothing ever got turned with the belt has been off.
Just wondering if its normal to be past about 1 tooth.
and also about the water pump.
thnx for your help
Old 05-29-05, 04:58 AM   #4 (permalink)
Blk/BlkGS6
Car 1: '94 Black/Black Legend GS Sedan 6 Speed
Car 2: '92 Silver LS Coupe
Car 3: '94 Cashmere L Sedan
Send a message via ICQ to legend4life Send a message via AIM to legend4life Send a message via MSN to legend4life Send a message via Yahoo to legend4life
I haven't done my own, so I can't help you there. But I would like to ask a favor while you have yours apart. Could you count the number of teeth on the crank sprocket that drives the belt for me? I would really appreciate it.
Thanks,
Imran
legend4life is offline   Reply With Quote
Old 05-29-05, 10:48 AM   #5 (permalink)
will count them today for you, as soon as i get a chance.
Old 05-29-05, 11:00 AM   #6 (permalink)
hondaman23's Avatar
Car 1: I have no Legends Left - End of an era!
All Marks should be within 1/4 of a tooth......
There should not be much varience in the reference marks as compared to the markers on the camshafts with the crank set at TDC on compression stroke for cylinder 1. If there is a timing belt tooth off, you need to get that cam back on time. You will loose gas mileage and power. May even throw a code or two.
95 Legend-Less, I don't know what to do with myself....
86 CRX w/D16A Turbo
hondaman23 is offline   Reply With Quote
Old 05-29-05, 11:03 AM   #7 (permalink)
Ok. How do I do that?
I figured it was alright because thats how it lined up, i never moved anything with belt off or never mad a mistake, so I went ahead.
If I put the new one on, pistons will not hit valves, correct?
thats the main thing I'm concerned about right now and I can fixthe timing later.
Ps. wp help too people.......
thnx
Old 05-29-05, 05:43 PM   #8 (permalink)
24 teeth on crank.....
bump
Old 05-29-05, 05:45 PM   #9 (permalink)
AKA Smartjay28
Johnny Kim's Avatar
Car 1: JDM KA7
Car 2: w203
thnx
hand turn it like 10 times, if u feel resistance, STOP~! its hitting the valve.
Old 05-29-05, 07:05 PM   #10 (permalink)
If i feel resistance....before I ever even took the belt off in the first place, there was resistance at certain points. So How is that possible, because my car ran fine.
I dont understand.........so if there is resistance, which there was....thats a problem?
Old 05-29-05, 08:22 PM   #11 (permalink)
Car 1: 1993 4Door
Hope these pictures help.
Crank Alignment (Notice the pulley key aligns with mark on block).
Right Cam
Left Cam
Legend93 is offline   Reply With Quote
Old 05-29-05, 11:31 PM   #12 (permalink)
thanks for the pics
im going to take pics of mine tomorrow and see if you can tell me if everything looks good
thanks again
Old 05-29-05, 11:41 PM   #13 (permalink)
A murder of Scarecrows Champion, Just Not Cricket Champion
Kenso's Avatar
Car 1: ITR 00-106
Car 2: 95 FZJ 80
iTrader Score: 26 reviews
Actually, it appears that both of those pics are of the same cam (driver's side). Anyways, you get the general idea. You need to have the marks aligned when you put the belt on.
ITR 00-106
95 FZJ-80
Kenso is offline   Reply With Quote
Old 05-30-05, 10:05 AM   #14 (permalink)
What do I do to check to make sure that my engine is in time?
because if it can be lined up and still be wrong, correct?
Old 05-30-05, 10:13 AM   #15 (permalink)
Blk/BlkGS6
Thanks for checking for me. Good luck on your TB
DIY Water Pump Replacement lycan First Generation Legend (1986-1990) 10 06-03-16 02:58 PM
Timing Belt Instructions 5spdLegend Second Generation Legend (1991-1995) 2 01-17-13 05:08 PM
Timing Belt Question ntujyug Second Generation Legend (1991-1995) 3 05-28-05 06:23 PM
Help Please Paulo Caramico Second Generation Legend (1991-1995) 5 02-27-05 10:59 AM
Done Timing belt yesterday masupra First Generation Legend (1986-1990) 8 06-10-03 09:37 AM
