Type1 to Type2 intake manifold 101 - The Acura Legend & Acura RL Forum
Old 09-16-06, 11:06 PM   #1 (permalink)
iTrader Score: 7 reviews
Everything you need to know about this mod is located in this thread. I will not cover the removal of the intake manifold due to the fact it's a 3-5 hour process. These pictures should help you understand what you can keep intact when removing the intake manifold:
Front:
Rear:
Intake manifold rear (The pink circle indicates where your EGR pipe -> Intake manifold pipe would remain intact during removal.
There is only 1 modification needed to perform this swap. A item called the PAIR Valve needs to be blocked. This entire unit is bypassed on all type2 engine. You will have to fabricate a metal block plate.
Where the unit is
unit blocked:
If you look at the rear picture of the intake manifold (2nd picture) and compare them to this picture, you can see how the entire unit is bypassed.
Why a type2? Well the fallowing image shows you exactly why. A 5-10 HP increase can easily be added. A port/polish could prove to increase a greater amount of HP.
Extra info:
The throttle body from a TCS type2 will not swap with a non TCS type1.
Everything else is swappable and identicle. that includes the EGR pipe, EGR system, screws,nuts,bolts you name it.
The lower plenum, middle plenum (VIS) is identicle on both motor.
Old 09-16-06, 11:09 PM   #2 (permalink)
Type I King
Car 1: 92 LS Sedan
Car 2: 91 LS Coupe 5 spd
Car 3: 95 LS 6 spd coupe
great post!
Old 09-16-06, 11:53 PM   #3 (permalink)
I like shiny
Breakout Champion
91LSMAN's Avatar
Car 1: 91 LS Coupe (GONE)
Car 2: Current-02 Corvette
Car 3: 94 LS Coupe (Bro's)
Excellant post.
91LSMAN is offline   Reply With Quote
Old 09-17-06, 01:06 AM   #4 (permalink)
Car 1: 1992
no. you can use the same throttle body
1992 Acura Legend LS sedan
GSteg is offline   Reply With Quote
Old 09-17-06, 11:13 PM   #5 (permalink)
A murder of Scarecrows Champion, Just Not Cricket Champion
Kenso's Avatar
Car 1: ITR 00-106
Car 2: 95 FZJ 80
iTrader Score: 26 reviews
Nice to see you finally got a chance to do this, I know you had it planned for a while. Hopefully you'll pass smog too now that the EGR system is all cleaned out.
ITR 00-106
95 FZJ-80
Kenso is offline   Reply With Quote
Old 09-18-06, 02:43 AM   #6 (permalink)
One Meeelion HP
sr5guy's Avatar
Car 1: 95 BMW 740I
Car 2: (860) 585-7200
Car 3: 91 LS Cpe 3.5 *sold*
iTrader Score: 44 reviews
So ballistic, what is your take on this mod? Is the butt dyno happy?
To reduce your NOX emmissions you may try retarding your timing a bit. There is an adjustment inside of the black control box. Check out the service manual or I can give you more details. Try running some fuel injector cleaner also. That can make it run a bit richer (leaner=more NOX).
-Matt
P.S. You should have stuck with a 3 way cat instead of the high flow, esp in california - HC, CO and NOX.
P.S.S. Try using some GM top engine clean or berryman b12 through the PCV valve. That breaks up alot of the carbon deposits that cause hot spots which in turn cause NOX. Just make sure you do it at night cause the smoke is gonna make it look like your cars on fire.
sr5guy is offline   Reply With Quote
Old 09-19-06, 12:19 AM   #7 (permalink)
Took me about 10months to start this mod lol. And it only took 3 days!
I'm going to get my original cat. installed so i'm garunteed to pass smog. I need to get this beast street legal!
-Matt
Hey thanks for the tips! I'm going to give the GM top engine cleaner a shot.
Old 09-19-06, 03:27 PM   #8 (permalink)
started with legend.com
Car 1: Fast Gray Rabbit
iTrader Score: 11 reviews
Ballistic, thanks for the great post! What's a 3-way cat(vs say a Magnaflo that I have on now?) What kind of thickness plate did you use to block off the PAIR valve? Are you gonna run chipped or stock ECU for smog? Let us know smog results. PM me your number and times to call if you're OK with it, I would love to talk to you about what you've done so far to your car. Again we all really appreciate the DIY! mods want to sticky it in the DIY section?
PS sr5guy, although it seemed obvious, I never thought about running a cleaner (I'd likely do Seafoam) at night, thanks!
hinow is offline   Reply With Quote
Old 09-19-06, 08:14 PM   #9 (permalink)
$er1f
iTrader Score: 6 reviews
Great job!
one,
'92 Legend Blk/Blk LS coupe manual
'92 Legend Wht/Blk LS coupe manual
'87 Celica Blk/Blk GT hatchback manual
'94 Legend Red/Tan LS coupe Auto (parts)
nupe07 is offline   Reply With Quote
Old 07-04-09, 06:35 AM   #10 (permalink)
HONDA FAN!
Honda Power's Avatar
Car 1: Honda Legend Coupe KA8
how hard is this to do?
is there a complete DIY to swap a T1 for a T2 intake?
I think you are going to need a T2 ecu to make it run at best how good do they run on a T1?
Honda Power is offline   Reply With Quote
Old 07-04-09, 04:45 PM   #11 (permalink)
sap
sap's Avatar
Car 1: 92 LS Sedan AT
Car 2: 93 L Coupe 6MT :(
Car 3: 86 Camaro IROC Z
Send a message via AIM to sap
I don't think there's a complete diy, but I hadn't seen this thread before either.
I don't think you'd need a Type II ECU, you're not really changing that much by swapping the intake manifold. Getting a chipped ECU is probably the way to go even if you don't do a manifold swap. Go over to acuralegend.org and PM Telion .
Visit the Legend Wiki
DIY: Intake Manifold Removal and EGR Cleaning petthepeep First Generation RL (1996-2004) 22 01-11-18 03:39 PM
EGR Pipe and Intake Manifold Chamber Connection LPB Second Generation Legend (1991-1995) 12 10-30-05 04:00 PM
Type 2 vs Type 1 Intake Manifold davedj Engine & Performance Modifications 12 09-16-04 12:26 AM
Intake Manifold Removal LPB Engine & Performance Modifications 5 06-03-04 10:48 AM
