VSS repair kit Vs. an entire VSS - The Acura Legend & Acura RL Forum
Old 07-19-06, 04:47 PM   #1 (permalink)
Which would you say is better? Because seeing as how i'll probably be needing one I'm looking at these two on ebay and was wondering what this excellent forums members think would be better.
http://cgi.ebay.com/ebaymotors/91-95...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/1991-...spagenameZWDVW
Yulri is offline   Reply With Quote
Old 07-19-06, 04:54 PM   #2 (permalink)
GS Hog
Golden Arrow Champion
LegendGS's Avatar
Car 1: 1994 Legend GS-Auto
Car 2: 1994 Legend GS-6 spd
Car 3: 1993 NSX-6 spd
You probably don't need the entire assembly, so no point in buying that since you'll be getting all used parts (i.e. might need to replace the electronics soon enough).
The repair kit is a brand new part, so you shouldn't have to worry about it for a long time after repair.
LegendGS is offline   Reply With Quote
Old 07-19-06, 06:16 PM   #3 (permalink)
LPB
Buy the "gut". By the time the mechanism goes, the car will be a lawn sculpture.
Old 09-05-06, 12:49 AM   #4 (permalink)
pasha95GS's Avatar
Car 1: 1995 GS Sedan
Replaced my VSS over the weekend....
My VSS was acting up recently. Called up Acura of August and their price was higher than getting it on eBay from the seller named "fast-imports". I just got the repair kit and intalled it over the weekend.
It took me a couple of hours but mostly because I took the entire plastic shroud off and didn't take the VSS assembly off completely. I worked on it as it danged from the PS hoses because I didn't want fluid coming out. A little harder to do it that way but worth it in the long run. I didn't lost much differential fluid either. Squirted some back in the diff hole before I put the assembly back into the differential. The worst part was getting the stoopid dust seal ring to stay in place while I put the dust cover back in place.
Anyway, everything works good now. No more jumpy speedo or flashing D4 - cruise is operational now also. The DIY was a big help and the kit also came with directions.
EDIT: Found this while browsing.... http://www.acuraworld.com/tsb/1994/B...560-py3-000%22
pasha95GS is offline   Reply With Quote
Old 10-20-06, 01:30 PM   #5 (permalink)
i got the manual on the legend off this site or another. but anyways.. what page is the directions on fixing the VSS?????
ALnut is offline   Reply With Quote
Old 10-20-06, 01:50 PM   #6 (permalink)
GS Hog
LegendGS's Avatar
This page.
Old 10-20-06, 05:13 PM   #7 (permalink)
Just wanted to confirm information I've received. I want to make sure it's okay to drive my car while the VSS sensor is not working. I haven't received my new one yet. I've read it's okay to drive the car this way until I replace the sensor. Is this correct.
LALEGENDGUY is offline   Reply With Quote
Old 10-20-06, 08:11 PM   #8 (permalink)
T The pimp
truonghthe's Avatar
Car 2: 93 Legend L AT
Car 3: 92Legend L AT R.I.P
if your VSS not working your gear will shift not very correct. It may be shift too soon or early since your trany can't get the signal from the VSS so it don't know when is the approviate time to shift and engine check light will come up. but its ok to drive. (if your car is a auto trany). I had drove my for more than a year now with the VSS death. it work rarely in a really hot day. but my is a 5spd so i can shift it any way i can or i want to.
In memory of 92 LS 5spd
"I AM LEGEND"
To This
truonghthe is offline   Reply With Quote
Interested in a Big brake kit? Bread Second Generation Legend (1991-1995) 27 08-31-03 07:37 PM
New HID kit arrives. Koji_H Second Generation Legend (1991-1995) 27 08-30-03 03:37 PM
leather repair kit ZiGGie Second Generation Legend (1991-1995) 1 05-30-03 04:33 PM
Please Respond ASAP KIT HELP wTnLeGeNd Second Generation Legend (1991-1995) 1 02-12-03 08:00 AM
Who would be interested in a real aluminum dash kit? Austin519 Second Generation Legend (1991-1995) 2 01-23-03 02:16 AM
