2005 RL Owners - Check/Sign in! - Page 5 - The Acura Legend & Acura RL Forum
Go Back   The Acura Legend & Acura RL Forum > Acura RL > Second Generation RL (2005 to Present)
Old 07-19-12, 11:15 AM   #61 (permalink)
At the time of its introduction, the Acura RL's SH-AWD was the first all-wheel-drive system that vary the distribution of power not only from front to back, but also side to side in the rear using a technique called torque vectoring. The RL can direct up to 70% of available torque to the rear wheels, and up to 100% of that available rear torque can be directed to just one wheel.
Anderson1427 is offline   Reply With Quote
Old 07-19-12, 11:16 AM   #62 (permalink)
In combination with a specially designed planetary gear set which can over-drive the rear wheels at up to 5% greater speed than the front wheels, the torque directed to one wheel, or torque vectoring, can have a steering effect.
Old 07-19-12, 11:17 AM   #63 (permalink)
As the car speeds around a curve, torque vectored to the outside rear wheel will push the rear end around the curve faster, just as paddling the outside oar of a row boat faster than the inside oar will cause the row boat to turn, to minimize the understeer common in front-heavy vehicles.
Old 07-19-12, 11:17 AM   #64 (permalink)
A first for the RL was the use of aluminum 4-piston front brake calipers over 12.6-inch cast-iron ventilated front rotors.
Old 07-19-12, 11:18 AM   #65 (permalink)
Bose Active Noise Cancellation (ANC) rounded out the suite. Always on, whether the stereo was on or not, ANC took input from two microphones placed in the cabin to analyze drivetrain-related low-frequency sound waves entering the cabin. The ANC sent information to the sound system to create a precisely shaped and timed reverse-phased audio signal from the door speakers and the subwoofer. The result was a dramatic reduction in engine and exhaust noise.
Old 07-19-12, 11:19 AM   #66 (permalink)
Heating and air conditioning systems were tied into a solar sensor and GPS positioning so that cabin temperature remained constant in a mixed sun and shade situation. Based on sun position and cabin orientation, the system could automatically send additional cooling air to the sunny side of the car to keep that occupant comfortable, while not freezing out the occupant on the shady side.-------
Old 07-19-12, 11:19 AM   #67 (permalink)
Unlike many in-car navigation systems, the Alpine DVD-based navigation unit allowed the driver to change destinations and routes "on the fly" while driving, rather than being locked out unless the car was in Park. The tightly integrated voice recognition system worked with the navigation system and could recognize spoken city and street names. Also unique at the time was two-way communication via AcuraLink satellite communication. Using a facility of XM Radio service, the system could send a variety of messages to the car, including service appointment reminders (appointments first made via Internet) or important messages such as recall notices.
Old 07-19-12, 11:21 AM   #68 (permalink)
The 2005 RL was also the first Honda vehicle to use the Advanced Compatibility Engineering (ACE) body structure, which has since proliferated throughout every newly introduced Honda and Acura vehicle design.
Old 07-19-12, 11:23 AM   #69 (permalink)
The ACE structure features extensive use of high-tensile steel and lightweight aluminum components in a front-mounted polygonal main frame, designed to engage vehicles of differing size and weight in a frontal collision and spread the forces through multiple structural pathways, while preventing or minimizing cabin deformation.
Old 07-19-12, 11:23 AM   #70 (permalink)
In more conventional non-ACE car structures, the SUV frame has a much greater chance of missing or over-riding the conventional car's major structural components and a greater chance of deforming the passenger compartment.
Old 07-19-12, 11:24 AM   #71 (permalink)
The 2005 RL car structure made extensive use of somewhat "exotic" materials for a car at this price point. These included aluminum alloy in the hood, front fenders, trunk lid and frame, front and rear subframes, suspension arms, front knuckles and bumper beams.
Old 07-19-12, 11:25 AM   #72 (permalink)
Magnesium was used in the intake manifold, and the two-piece center drive shaft was made of a carbon reinforced composite.
Old 07-19-12, 11:25 AM   #73 (permalink)
The metric sized, run-flat Michelin PAX System wheels and tires are equivalent to 18" x 9" wheels and 245/45-R18 conventional tires. The previously standard color-matched mud guards were removed in 2006.
Old 07-19-12, 11:26 AM   #74 (permalink)
For 2007, the Acura RL was offered in three trim levels, detailed in the table below: a "standard" or "base" package, a newly defined "Technology Package," and the highest level trim, the "Technology Package with CMBS/PAX."
Base model cars were well equipped, but deleted certain features such as the navigation system and Adaptive Front Lighting System (AFS), and substituted plastic simulated wood for the dashboard maple wood trim.
Old 05-01-16, 06:19 PM   #75 (permalink)
new On this site.
Hey Acura Rl owner's. I'm new to this site and need some help with my 2006 white rl. I just found out my trunk will not open, either from the outside or when I push the button from the inside. I looked for a fuse but have no clue on where to find it. Can anyone help????
Tony M. is offline   Reply With Quote
Jose3030's great idea... Patent The Lounge 34 07-06-05 05:58 PM
