-   Audio, Video, & Electronics (https://www.acura-legend.com/vbulletin/forumdisplay.php?f=6)
-   -   G2 Legend Stereo FAQ (https://www.acura-legend.com/vbulletin/showthread.php?t=45115)
sap 05-01-09 01:02 PM
Originally Posted by trav4517 (Post 1475219)
The problem i am having is that.
last night my radio and Clock had cut out at the same time. But i noticed if i connect the radio power wire (red) and the memory wire (yellow) they work but of course i loose all presets and clock memory every time i turn the car off. Its almost as i lost all memory in my car. Can anybody help me?
Have you checked for blown fuses? There should be a 7.5A fuse in the under-hood fuse box that would cut the constant battery voltage to the HU if it's blown.
danr355 06-30-09 10:10 PM
Amp or no amp
Hi guys. Read your post on bypassing the stock amp and the location of it. My car is a 94 legend L. I replaced the stock HU with a alpine, the stock was a bose tape deck and read 4ohm on the side, I also have the stock cd changer in the back. The alpine worked for a day then the sound quite. Bench tested the alpine and worked fine so i thought the amp went, problem is i don't believe there is a amp in this car because where you say the stock bose amp should be is another case with four pluges going in to it and on the pass side another case with three plugs. So not sure what the problem is yet. Any ideas? Any help would be appreciated. Thanks
Randy 07-31-09 02:21 PM
Questions regarding aftermarket installations
As my standard BOSE head unit is almost completely spent, I'm planning to replace it with an aftermarket system. Now I'm not sure whether my anti-theft system is aftermarket as well. My guess is that it's factory installed as I don't see anything added under the steering wheel or elsewhere in the cabin, and the anti-theft lights on the stereo head unit and door are still flashing.
Questions
1) How will an aftermarket head unit impact the anti-theft system?
2) How will it work with the power antenna (which I'm replacing as well)?
3) There is a 11cm x 19cm space were I to remove the head unit. Can anyone recommend a stereo/cd changer that fits in this space?
Thanks for your time!
sap 07-31-09 04:01 PM
Questions
1) The OEM alarm will work just fine.
2) The power antenna will work just fine, every aftermarket deck I've ever seen has an output for raising a power antenna.
3) If you just want a standard sized HU then go to walmart or something and get a kit that'll fit the opening. While you're at it make sure you find a harness adapter so you don't have to hack up the OEM stereo wiring.
JTJohnny102 09-11-09 06:12 PM
I have the standard bose system and my rear speakers for whatever reason have stopped working so I plan on replacing the front and rear. I'm not familiar with speakers and ohms and so forth and I'm still a little confused. So should I or can I buy speakers that are 2 ohm? or should I buy 4 ohm speakers? Any recommendations, I dont need anything crazy, just something to replace the stock, at least something as good if not better than stock, my headunit is alpine btw.
sap 09-11-09 07:46 PM
A stock system in a '93 L should have 4-ohm speakers, so you should be able to replace the stock ones with pretty much anything on a store shelf.
Whether it'll actually solve your problem or not I couldn't tell you.
JTJohnny102 09-13-09 06:58 PM
can someone explain to me about the two way three way and four way speakers..not quite sure what that relates to.
Maadi 03-30-10 04:54 AM
Two way speaker, there are two kinds of drivers, A woofer for low frequencies and another driver for mid and high frequencies. In a three way speaker there are separate low, mid and high frequency drivers. Typical crossover frequencies might be 500Hz and 4kHz. Four-ways combine a woofer, a mid range, a tweeter, and a super tweeter.:thumbsup:
angieboyd 09-05-10 11:21 AM
Question??
I bought my daughter a 1991 Acura Legend for her first car. There were no owner's manuals with the purchase.
Since I purchased it, the battery has died. I replaced the battery, and now I get this "Code" error when turning on the radio. I found in an online owner's manual that this is an anti-theft feature of the vehicle.
Is it possible for me to go to an Acura Dealer, and possibly get this code reset or get the original code?
Giza1983 04-29-11 01:54 PM
Hey guys i have a question, well more like need some assistance. I have a 1992 Legend, base model, and when i got the car i realized that the previous owner had an aftermarket radio and amp and what not installed. They removed the amp and new radio but left all the wiring. So i have the rca cables, ground and remote cables still hooked up inside the car but just the factory Bose stereo to reconnect. I'm trying to figure out how to reconnect the factory rear speakers... would anybody know how to do that? I reattached the harness wires to the factory Bose system, so my front speakers work but my rears dont. Obviously they had been attached to the amp by the previous owner. I'm not very electrical savvy but it doesnt seem very hard to just reconnect the wires, im just unsure if i'm supposed somehow run the rear speaker wires through floor and side of my car back into the harness that attaches to the Bose stereo or what??? Any info would be helpful. Thanks!
Chico 06-29-11 03:31 PM
Originally Posted by alexc (Post 380422)
1991-1992 LS ------ Bose
Bose*
The Bose system uses the 2100 model AM/FM/Cassette tuner and an 80Wx4 (peak power) amplifier mounted behind the rear seat. The Bose speakers in this system present a 2 ohm load per channel, which the OEM amplifier is equipped to handle.
Replacing speakers in the Premium system
There are several brands which make 2 ohm speakers. The ones I know of are Soundstream and Image Dynamics. They can be difficult to find. The other option is to simply use regular 4 ohm speakers. The volume of the 4 ohm speakers will be half of what it should be due to the mismatched resistance. If you replace only the fronts, or only the rears, you can use the fader to compensate for the difference in volume between front and rear.
so, can't i get exactly the same ones with stock ones? I could not see their model number, all I know is the brand is bose :(
Densetsu 03-12-12 02:25 AM
I see this thread is old but Im in abit of a hurry. I'll apologize in advance because Im sure my question has been asked 10 times before, but Im new..
I recently bought a 92 Legend LS sedan with the Bose 2100 stock stereo. Amazing car, and it will be alot of fun to work on. But unfortunately 3 of the 4 stock speakers are almost completely blown :/ I dont do very much audio work so I thought Id ask the experts
these front speakers
Amazon Search: "Infinity Reference 6032cf 6.5-Inch 180-Watt High-Performance Two-Way Speakers"
& these rear speakers
Amazon Search: "Infinity Reference 9632cf 6x9-Inch, 300-Watt High Performance Two-Way Loudspeaker"
They claim to be 2ohm impedance but will these ^^^ speakers blow my stock amp? Sorry for not having a link, it wont let me until Im not a newbie. Thanks much
OrangeGen1 03-12-12 02:39 AM
they should be fine the 180 watt is only peak power so thats the max, if i remember right thats whats in my car but im not using the factory system. and if you dont mind me asking were you from in ohio ?
Densetsu 03-12-12 02:53 AM
Thanks for the quick response man! Im out east of Columbus, towards Newark. I'll give those a shot & post back after I work them out. Any other ideas are welcome
d1jinx 03-13-12 09:03 AM
crutchfield has a pretty good reference list of what fits and whats best for your car. check them out.
NO I dont work for crutchfield.
