16x7 +38 offset rubbing. - The Acura Legend & Acura RL Forum
Old 05-06-11, 12:57 AM   #1 (permalink)
Car 1: 92 legend
Hi everyone,
Recently got some 16x7 wheels with +38 offset, the tires were 225x55x16, both front and rear gaps look fine (rear about 1.25in and front about 1.5in). However, when I go over bumps in the road or dips, I can hear the back tires rubbing against something. If I put about 150-200lb of weight in the trunk, the rear tires will rub when turning and the gap goes down to about 0.5in. My rear struts were shot, and I'm wondering if this could be the reason? Have any of you guys experienced rubbing with my setup?
Thanks in advance,
mbevo
mbevo is offline   Reply With Quote
Old 05-06-11, 01:52 AM   #2 (permalink)
Car 1: 1995 Acura Legend
Car 2: 2004 Honda Civic
I'm not running that set up but I can bet that the rear struts are to blame. If that doesn't fix it you may have to run a lower profile tire, I do know that for a 17" rim on a legend you need a 45 series tire so I would imagine that a 50 would be best for a 16".
95legendtracKar is offline   Reply With Quote
Old 05-06-11, 02:34 AM   #3 (permalink)
Car 1: 92 legend
Yeah I'm pretty sure that's the problem too, my rear right ball joint is also shot, so I'm going to replace all of those rear suspension components and then re-evaluate. Hopefully the problem goes away since the tires are brand new.
Old 05-06-11, 06:32 PM   #4 (permalink)
Fut RIP
L3GDKANG/JDMKANG's Avatar
Car 2: 92 Alpha/ AlphaT KA8
Car 3: 91L,93LS,94LS KA7's
iTrader Score: 39 reviews
you need to check the tire size im sure thats your problem!
Originally Posted by Blackend
Old 08-28-11, 02:32 AM   #5 (permalink)
Car 1: 1995 Acura Legend LS Type II 6-speed
My guess is you need a lower tire profile. I spent a while making sure my wheel and tires would fit without rubbing. I have it lowered an inch, have a half an inch wider rim, and a higher offset, and I don't have any problems. Probly a 45 or 50 profile tire is you answer. Choosing the right wheels and tires is a real headache
redsfan2144 is offline   Reply With Quote
