17x9.5 +51 - Page 2 - The Acura Legend & Acura RL Forum
Old 04-28-09, 10:36 PM   #16 (permalink)
Fut RIP
L3GDKANG/JDMKANG's Avatar
Car 2: 92 Alpha/ AlphaT KA8
Car 3: 91L,93LS,94LS KA7's
iTrader Score: 39 reviews
Originally Posted by whyteLegend View Post
that because the offset was wrong
here is a set of 19x9.5 & 19x10.5 with correct offset .. *car is sold*
yea but thats no legend either.
Originally Posted by Blackend
Old 04-28-09, 10:39 PM   #17 (permalink)
3.52 ..Chicken & Dumplins
whyteLegend's Avatar
iTrader Score: 17 reviews
that is why i showed mine with 17x8 lowered in the previous pic
Click for Deep Discounts
http://4450488.shopwize.com
Old 04-28-09, 10:42 PM   #18 (permalink)
Fut RIP
i see now.
Old 04-29-09, 05:39 PM   #19 (permalink)
misdeismo's Avatar
For a STANDARD legend, meaning no drop and no fender mods, you would need at least +67 offset for it to not stick out at all. Once you start throwing in other modifications you can decrease the offset requirement. Right now, I have a set of 18x8.5 +48 offset rims that are flush with the front fender on my coupe but my car is lowered and runs neg. camber.
misdeismo is offline   Reply With Quote
Old 04-29-09, 05:48 PM   #20 (permalink)
sap
sap's Avatar
Car 1: 92 LS Sedan AT
Car 2: 93 L Coupe 6MT :(
Car 3: 86 Camaro IROC Z
iTrader Score: 6 reviews
Send a message via AIM to sap
He is using 17" rims which leaves him will a lot more room that guys using 19,20 & 22's ..
with 225/45/17 or 235/40/17 tires he will be just fine .. If you choose not to slam the car in the ground... I had 17x8 +40 with 235/45/17 tires and a 1.1" dropped
In order to have the wheels not stick out any further than your 17x8's the offset would have to be increased by 3/4" (half of the difference in the wheel widths). 3/4" ~= 19mm, so the the offset would have to be +59. At +51 the 9.5" rim will stick out 8mm more, just under 1/3", than your 17x8's.
I have no idea how much room there is in the wheel well either, as you increase the offset you're moving the wheel further in too.
Edit: In comparison to Willie's wheels @ 8.5" wide and +34 offset, a 9.5" with +46 or +47 offset would stick out the same amount. 9.5" wide with +51 should sit about 1/6" further in.
Visit the Legend Wiki
Old 04-29-09, 08:05 PM   #21 (permalink)
whitecruiser's Avatar
Car 1: 95 L Coupe
iTrader Score: 4 reviews
Thanks for all the help guys... but the shop that is selling the wheels won't let me test mount them. And at $1300 I can't afford to take the chance of the wheels rubbing the fender or the inside wheel well.
FS: 94-95 Coupe Fog lights
whitecruiser is offline   Reply With Quote
Old 10-30-11, 10:58 PM   #22 (permalink)
TheCrimsonChin's Avatar
Car 1: 92 Legend LS Coupe
Car 2: 03 TL Type-S
Waddup
Originally Posted by L3GDKANG/JDMKANG View Post
way too wide for our cars you need a 8 and down size wide wheel. more then likely it will rubb on the out side my 8.5 are already there!
Your rims are 8.5? Did you have to roll your fenders? Cuz im tryna put some 17 in M5 BBS's on my joint. I'm tryna find out about the major problems i might run into. I think you gave me some tips about the spacers, but the spacers I got are like an 1.25" thick. So im almost sure im gunna run into mad problems.
TheCrimsonChin is offline   Reply With Quote
Old 10-31-11, 03:02 AM   #23 (permalink)
Fut RIP
Yea that's way to thick you will need to find som smaller adapter plates cause that gonna make your rims stick out way more so your offset will change as well. Rolling the fender lips will have to be done or even a fender pull will be needed.
Old 10-31-11, 12:07 PM   #24 (permalink)
Car 2: 03 TL Type-S
You think it would be possible to change out the whole hub to an 05 RL hub? Would the legend axle fit into the 05 RL hub?
Old 10-31-11, 06:28 PM   #25 (permalink)
Fut RIP
no sure about that 1
