18x8 wheels tire question - The Acura Legend & Acura RL Forum
Old 09-12-06, 05:21 PM   #1 (permalink)
whitecruiser's Avatar
Car 1: 95 L Coupe
iTrader Score: 4 reviews
18x8 Piaa Super Ross wheels tire question
18x8 +50 offset... will 225/45/18 tires rub? (on a coupe)
whitecruiser is offline   Reply With Quote
Old 09-12-06, 05:53 PM   #2 (permalink)
not likely on a coupe, on a sedan probably. i had that exact setup on a sedan and the rear passenger side rubbed. but it also depends on the manufacturer of the wheel. different manufacturers measure offsets differently.
amplified is offline   Reply With Quote
Old 09-12-06, 06:14 PM   #3 (permalink)
Car 1: 95 L Coupe
so would it be safe to just run 225/40/18 tires?
Old 09-12-06, 06:18 PM   #4 (permalink)
it's likely to be the same, the coupe has a larger wheel well than a sedan so the profile of the tire shouldnt matter much (other than for speedo/odometer issues). its more the width of the rims, offset and width of the tires that matters more.
Old 09-12-06, 06:20 PM   #5 (permalink)
Car 1: 95 L Coupe
well i'm planning on getting 18x8 Piaa Super Rozza wheels. Which tire size would you recommend.
Old 09-12-06, 06:27 PM   #6 (permalink)
225/40/18 is closer to stock, therefore it doesnt affect your odo as much, but the ride will be a bit harsher than a 45 series tire. basically its just looks vs comfort.
also if there are lots of potholes on the streets around your area you might wanna think about getting a tire with a larger profile to protect the wheels for getting bent. if they're smooth the lower the profile the better lol.
Old 09-12-06, 06:30 PM   #7 (permalink)
Car 1: 95 L Coupe
how do you go about comparing two different size rims w/ tires, in this case stock vs. the 18" to deteremine if their overall specs. are the same?
thanks again for help.
Old 09-12-06, 06:32 PM   #8 (permalink)
http://www.miata.net/garage/tirecalc.html
most people recommend being within +/- 3% of stock
Old 09-12-06, 06:41 PM   #9 (permalink)
Car 1: 95 L Coupe
sorry but i'm a newbie. Just got the legend last week and it came w/ aftermarket 17" wheels. Can you please tell me the specs. on the stock tires?
Thanks
Old 09-12-06, 06:43 PM   #10 (permalink)
205/60/15
Tire question starflyer Second Generation Legend (1991-1995) 5 03-23-05 11:49 AM
Quick question about tire sizing, the speed sensor etc... Theava Second Generation Legend (1991-1995) 16 02-24-05 08:07 PM
All NOPI 2004 Threads in here! sleeprlegendcp Meets 26 09-16-04 04:30 PM
tire size question for '92 Legend vayankee Second Generation Legend (1991-1995) 0 12-05-03 02:17 AM
question about tire sizes WhiteLegend Second Generation Legend (1991-1995) 4 02-27-02 09:07 PM
