-   Wheels, Tires, Brakes, and Suspension (https://www.acura-legend.com/vbulletin/forumdisplay.php?f=94)
-   -   95 Legend Coupe Rear Coil Springs (https://www.acura-legend.com/vbulletin/showthread.php?t=166740)
glsmoove2000 10-07-20 05:03 AM
Hello everyone I have been looking for some rear coil springs for my 95 Legend and can’t find anything because it all says it’s discontinued. I don’t want any lowered springs, I want normal OEM springs. I replaced the struts last year so they are fine but I didn’t do the springs then and now I do. I know there has to be some part numbers that will fit, it’s just springs and nothing crazy but I couldn’t find anything. Can anybody out there give me any info?
SeeNBSeen 10-13-20 08:08 PM
Springs question
Why are you looking for springs? is it sagging, and you want more height?
Our 93 is low all around, and our driveway is next to impossible in parts where there's a rise as you transition from street to driveway. With more than a driver in the car, it scrapes... Sounds like hell.
I have been looking into lifters, as I want the car to be a tad taller for this part of the driveway. I found some spacers that sit on top of the front strut, accompanied by longer bolts of course. Maybe there is a rubber pad that will help in the rear? I have seen this kind of item in the past, but can't remember where at the moment. I recall they came in different thicknesses, too.
Maybe someone knows where these are available?
Good luck, and please post your source and results if you find a solution!
Andy
MIZEMIKE 10-14-20 05:22 AM
2 Attachment(s)
I have found 1 OEM rear spring (Honda # 52441-SP0-G01) that fits your vehicle.
I found it on Mercari app (please see attached photo).
If you're not familiar with Mercari it is similar to Ebay and you can download it for Android and Apple.
I also have attached a photo that shows this Honda/Acura part fits 1991-1995 Legend Sedan/Coupe with either a 4 speed automatic or 6 speed manual transmissions.
I hope this helps!
M.Mize
