Any 2002-04 RL owners use G2 Legend konis on stock springs? - The Acura Legend & Acura RL Forum
Old 05-27-09, 06:20 PM   #1 (permalink)
Well as the title states. I am wondering if anyone with the 2002-2004 Acura RL has used the oem springs with only the substituion of the G2 Legend koni red struts?
I actually like the ride of the RL as it sits but would like to lower it about an inch. i figure this might be the easiest route.
Purchase Koni reds for G2 Legend and machine grooves into them for the ride height I want. (I think theyre only like 3/4-1/2 inch but I would need to verify the locations of the perch mount grooves.)
I know about the pinchfork needed and the rear bushing needed to be swapped.
Ive been searching for 2 days straight and I dont think anyone has done this since it seems G2 Legend springs are used in conjunction with konis on the RL's.
I'm a little tired of comparing spring rates on coilovers for different cars along with whether or not they are rebound/compression adjustable and mind the fact Im not a big fan of linear spring rates.
SO I am down to the point where I do not want to wait 2 months for suspension components I might not like. I "think" I am down to these 2 choices.
1. use g2 Legend konis on my springs and machine grooves accordingly to provide the correct stance on my RL which already has a decent spring ratio.
2. go for the best coilover I can afford which would be a buddy club for the TSX. It seems to have a comparable spring rates that would work on the RL along with the shock being adjustable. Of course then I would have to get used to the linear spring rate which might be a bad idea with someone with a bad back.
OLD_HATCH is offline   Reply With Quote
Old 06-09-09, 03:36 PM   #2 (permalink)
Well if anyone is interested, I lowered my RL on Konis 1-1/2" in front and 1" in the rear. Its not a completely bolt on affair but doable none the less.
I will post pics later.
Old 06-10-09, 05:06 AM   #3 (permalink)
ビップスタイル Heavy Hitters
OneBadNA1NSX's Avatar
Car 1: 2004 3.5RL
Car 2: 2001 3.5RL
Car 3: 2009 Cayenne S
Send a message via AIM to OneBadNA1NSX
Hopefully I helped you out with the rear struts! Anxious to see the pics !!
2001 Acura 3.5RL Indigo Blue Pearl/Tan
Custom Exhaust
Apexi Intake Custom Ksport
2004 Acura 3.5RL Nighthawk Black Peark/Black
2009 Cayenne S Meteor Grey/Black
OneBadNA1NSX is offline   Reply With Quote
Old 06-13-09, 12:43 AM   #4 (permalink)
so how did the install go?
pmendoza502 is offline   Reply With Quote
Old 06-15-09, 10:51 AM   #5 (permalink)
B+O
I'van der Rohe
Towers of Hanoi Champion
B+O's Avatar
Car 1: why?
Send a message via AIM to B+O
apparently the install/review can be viewed over at
w w w . a c u r a l e g e n d . o r g
