Anyone running 18x7.5s with a +42 offset...even doable dropped? - The Acura Legend & Acura RL Forum
Old 09-29-06, 04:33 PM   #1 (permalink)
Question Anyone running 18x7.5s with a +42 offset...even doable dropped?
EDIT I just ordered a set of wheels that are a 45 offset
Well I have these set of 18s... they are 7.5 wide with an offsetof 42. I am dropping them on a set of JICs and am worried about rub cause it is a sedan and it a agressive offset.
So is anyone running a lowered car wih the same wheel dimensions? And does anyone have any pics?
The wheels..
The goodies...
And my ride..
badboyr66 is offline   Reply With Quote
Old 09-29-06, 04:39 PM   #2 (permalink)
Homers Beer Run Champion
Gride_Cruiser's Avatar
Car 1: 1991 KA8
I think it'll be fine, I've seen people ran the same wheel specs and lowered.
Gride_Cruiser is offline   Reply With Quote
Old 09-29-06, 04:42 PM   #3 (permalink)
K L E A N M O D
Thai.95LCoupe's Avatar
Car 1: 1995 KA8 *R.I.P*
Car 2: 1997 S14 *SOLD*
Car 3: 2004 GTO
Be prepared for a stiff ride. Run 225/40/18 and get the rear fenders rolled and you ill be fine.
-1995 KA8 MODIFIED-R.I.P
-1997 S14a-SOLD
-2000.2 Millenia S- Blown & SOLD
-1996.8 S14a-SOWED
-1995.8 S14a- SOLD
-2004 GTO-R.I.P
-1998 S14a
-Holy Rollerz CCC Member-
Imitatated. Never duplicated.
Thai.95LCoupe is offline   Reply With Quote
Old 09-29-06, 04:47 PM   #4 (permalink)
Man I hope it will work. Anyone else have any info or pics to post?
I found a old pic of my Accord...s ometimes I miss it
Old 09-29-06, 05:05 PM   #5 (permalink)
the rims will extend out an extra 36mm from stock. you may have problems with rubbing especially on the rear passenger side. if it does rub you can either roll the fenders or run more negative camber (downside of this is you'll go through rubber faster).
amplified is offline   Reply With Quote
Old 09-29-06, 05:31 PM   #6 (permalink)
Car 2: 1999 Acura 3.5RL
Car 3: 2004 GMC Sierra Z71
You'll definitely rub if you don't roll your fenders.
Old 09-29-06, 05:42 PM   #7 (permalink)
If it is just rolling the fenders I am not too worried. I hope they work. If not snow is on the way so the car will be parked soon either way.
Still hoping for pics if anyone has anything to post
Old 09-29-06, 07:07 PM   #8 (permalink)
Agreed.
+42 for 7 inch wide, plus 45 for 7.5. So you are going to be high offset (sticking out) almost a 1/2 inch from what is recommended. I would try to find something higher offset, or at least roll the fenders.....
tnelson is offline   Reply With Quote
Old 09-29-06, 08:17 PM   #9 (permalink)
TruGreen's Avatar
Car 1: 94 GS 6-Speed
Car 2: 93 Accord SE
You will rub depending on how low your drop is. My set up:
18 X 7.5
Offset: 48
Tires 225/40 -18
Koni Reds
H&R Springs
No rubbing. You need a higher offset than 42.
94 GS 6-Speed with 2011 V6 Accord Coupe Wheels
TruGreen is offline   Reply With Quote
Old 09-29-06, 10:33 PM   #10 (permalink)
I am running the same wheel size and JIC setup on my coupe, you will have to role the rear fenders and bend the fender well tabs up for the front fenders. I am dropped probably more that I should be but it is fine.
pjslegend is offline   Reply With Quote
Old 09-29-06, 11:12 PM   #11 (permalink)
StimulusPackage's Avatar
Car 1: 95 6spd Coupe Milano Red
Car 2: 00 Acura Integra GSR
Car 3: 06 Acura MDX
iTrader Score: 11 reviews
Send a message via AIM to StimulusPackage
18 X 7.5
Offset: 48
Tires 225/40 -18
Koni Reds
H&R Springs
TruGreen, do you have more pics? I would really appreciate some all around pics of your drop with your setup on your car. I would really HATE having to sell my rims since the offset is not high enough. How hard is it to roll fenders anyway?
StimulusPackage is offline   Reply With Quote
Old 09-30-06, 12:03 AM   #12 (permalink)
It's not hard, there's a fender rolling tool that you can use to do it, or some people opt to use a baseball bat lol. The key is to heat the paint and work cautiously so as to not to crack the paint, but this is also dependent on how much the fenders need to be rolled.
Old 09-30-06, 12:41 AM   #13 (permalink)
Car 3: 06 Acura MDX
There is NO WAY IN HELL I am dong that to my car.
Old 09-30-06, 02:26 AM   #14 (permalink)
Well what is your offset though?
Thanks for the replys.... And thanks for the pics... post more someone
Well I cannot afford new wheels now... though I am looking.
Old 09-30-06, 05:00 AM   #15 (permalink)
TruGreen's Avatar
Car 2: 93 Accord SE
Here are some more pics:
with trunk fully loaded no rubbing - 500+ mile road trip
No fender roll required
wheel offset question Stu Second Generation Legend (1991-1995) 8 01-03-06 01:24 AM
Anyone with 235/35/19? MysticalLegend Second Generation Legend (1991-1995) 6 08-05-04 09:25 PM
Hey Any of You Running 18x7.5 with A +42 or +43 Offset.... And have Pics? rawdog805 Second Generation Legend (1991-1995) 6 06-27-02 10:21 AM
Offset Question MC Second Generation Legend (1991-1995) 16 02-12-02 08:46 PM
