Attn. Legend owners with RSX wheels - Page 2 - The Acura Legend & Acura RL Forum
Ľ Auto Insurance
Ľ Wheel & Tire Center
Old 06-18-06, 07:49 PM   #16 (permalink)
Car 1: 1992 Acura Legend
Originally Posted by 1_Hot_Legend_L
They will put added stress on the wheel studs. Unless you have them braised onto the wheels and then it's just changing the offset of the wheels. There is an Idea if you still wanna use the RSX wheels, have the spacers braised onto the wheels.
BTW, braising for aluminum is the same as welding for steel.
Ah ok, adding spacers basically changes where the load of the car is on the wheel studs, taking it from closer to the hub to more of the middle of the stud making it easier to break a stud?
drmonkey is offline   Reply With Quote
Old 06-18-06, 07:52 PM   #17 (permalink)
***ned
Correct. This is especially true on any Honda vehicle because the weight of the vehicle is not supported by the studs. It is supported by the hub ring in the center. Now when you add spacers to the combination you will lose that center ring because the spacer will not have it. SO basically you will not only be putting all the load on the studs but you will also be moving it out 1/2" or more.
1_Hot_Legend_LS is offline   Reply With Quote
Old 06-18-06, 08:04 PM   #18 (permalink)
Socol's Avatar
Car 1: CL-S (Daily Driver)
Car 2: ObsidianBlack KA8
iTrader Score: 6 reviews
And then you'll watch your wheel studs break off one by one.
Socol's Basic Website
Socol is offline   Reply With Quote
Old 06-18-06, 08:05 PM   #19 (permalink)
***ned
And then the wheel beating you down the road as you skid to a stop.
Old 06-18-06, 08:18 PM   #20 (permalink)
Socol's Avatar
The unfortunate part is that what I said above is from personal experience.
Old 06-18-06, 08:20 PM   #21 (permalink)
***ned
Same here and I have a pic of it:
And here is the end result:
Old 06-18-06, 08:21 PM   #22 (permalink)
iTrader Score: 13 reviews
What did you do to solve this problem?
slick is offline   Reply With Quote
Old 06-18-06, 08:40 PM   #23 (permalink)
Socol's Avatar
Replace the broken wheel studs....
Actually, I looked into the possibility of buying a longer wheel stud kit which is about $120, plus labor to get it installed. Scraping that idea because itís not cost effective to me I'm currently solving the problem by selling my wheels and finding new ones. So who wants to buy some RSX wheels?
Old 06-18-06, 08:41 PM   #24 (permalink)
Damn, so your saying that I should look into getting different wheels then? I'm going to look at the brake calipers first to see what type of clearance I have, and what I might be able to modify.
Old 06-18-06, 09:05 PM   #25 (permalink)
Well, me and my buddy(building a 54 Belair right now and getting ready to convert my old Z34 to rwd) are going to get together here in a few weeks to see what we can do about the calipers.
Old 06-18-06, 09:19 PM   #26 (permalink)
***ned
Your best bet would be to leave the brakes alone and work on the wheels. Either add material to the backside of the wheel or braise the spacers to the wheels.
Old 06-18-06, 10:02 PM   #27 (permalink)
Personally, I wouldn't braize material to the wheels, as it's only 1/3 as strong as a weld. I would just have it all welded together if I go that route.
Old 07-08-06, 11:11 AM   #28 (permalink)
Illmatic's Avatar
Car 1: Rosewood L Sedan
Send a message via AIM to Illmatic
I'm thinking about buying some RSX Wheels but Don't want to run into any problems like this one. So Will RSX Wheels fit without any other modifications besides boring them out?
Picking up the pieces...
- JDM Headlights
- Clear Bumper lights
- Iggee Seat Covers
- New Sound System
- Catz XLO Fogs
- 20% Tint
Illmatic is offline   Reply With Quote
Old 07-09-06, 12:19 AM   #29 (permalink)
misdeismo's Avatar
which rsx wheels are these, the 16" or the 17" A-spec ones?
misdeismo is offline   Reply With Quote
Old 07-09-06, 12:33 AM   #30 (permalink)
Two words!
Hubcentric Spacers
Herb is offline   Reply With Quote
Will the Lexus SC 430 Wheels will fit on the Acura Legend Sedan? OCL-OrangeCountyLegends Second Generation Legend (1991-1995) 25 04-25-06 12:38 AM
F/S - 1992 Legend OEM Stock Wheels lsurob OEM Parts 0 12-01-05 01:00 AM
fitting 17x8 5lug 114.3mm acura tl wheels on a 94 legend w 15 x 6.5 stock wheels Legend_me Second Generation Legend (1991-1995) 3 11-02-05 09:13 PM
RSX wheels and G2 kfk256 Second Generation Legend (1991-1995) 1 08-15-03 09:32 PM
Bay Area Legend Owners......Looking for Reliable Owners to Set up Club 49ER DJ Meets 0 03-17-03 03:12 PM
