Coilover, Shocks, Struts, & Springs by B+O + Official suspension guide by Swift - Page 2 - The Acura Legend & Acura RL Forum
Old 08-22-06, 12:17 AM   #16 (permalink)
iTrader Score: 24 reviews
Originally Posted by badintentions
1.5 is not enough for that kit. that is what i have. get the ball join one. i still have 1 degree of negative camber (in specs???). and the 1.5 kit makes the upper control arms hit the fender... and that is after the shop grinded them down so it would not rub as much. get the ball joint ones!!!
idk maybe, my view on it is you don't need a camber kit at all, maybe in the rear. just make sure your toe is adjusted properly
Old 08-22-06, 12:37 AM   #17 (permalink)
Playing with fire?
:nono
ivanj is offline   Reply With Quote
Old 08-22-06, 12:36 PM   #18 (permalink)
badintentions's Avatar
Car 1: 1994 gold Legend 6spd 2dr.
Car 2: 1956 mg td-sold
Car 3: 03 RC51
Send a message via ICQ to badintentions Send a message via AIM to badintentions
http://www.sfxperformance.com/parts/INT999025.htm this is the camber kit i have. it makes the control arms hit the fender. i would not get this one because with his drop (the same as mine) you can not dial out all of the camber (increased tire wear) this kit is not very good for spirited driving, so there is no point in leaving all of that camber.
94 l gold 6 spd (sold)
94 l sedan 5spd.(totaled)
02 IS300 GPW 5spd (sold)
88 325I -schwartz DD (beater)
05 tundra SR5 4x4 (sold)
10 genesis coupe 2.0t
badintentions is offline   Reply With Quote
Old 08-24-06, 04:11 PM   #19 (permalink)
what!
kotetu's Avatar
Car 1: 95 LS Coupe 6 spd
Car 2: 02 TT225 Quattro 6sp
Car 3: 94 L Cpe 6spd - sold
iTrader Score: 20 reviews
if you're going with TSX suspension, get the TSX forks at $40 each so that you have a place to mount your brake lines. The forks are interchangeable and will make your suspension fit better.
kotetu is offline   Reply With Quote
Old 08-26-06, 02:58 AM   #20 (permalink)
Car 1: LEGEND TYPE 2 JDM SWAP
iTrader Score: 6 reviews
Ok guys thanks for the advice. I got the toe adjusted and gonna keep an eye on the tire wear. It doesnt seem that bad at the moment. The front tires look like they have a bit of a lean, but If anything does seem to go wrong i'll get the balljoint kit. I read through the threads and the balljoint kit seems to have best results. Thanks again!!
brickcitysaint is offline   Reply With Quote
Old 08-26-06, 09:25 AM   #21 (permalink)
swift's Avatar
Car 1: 92' C35 KA8 5spd
Car 2: 92' Ka8 5spd turbo
My toe is now adjusted at 0 degrees in front. Rear I could not do because adjustment bolt is rusted up.
Camber not adjusted.yet.
215whp+
Old 08-27-06, 11:17 PM   #22 (permalink)
as long as you're not more than 2-3 degrees or so(catera's for instance have 2 all the way around from the factory with no tire wear issues) camber isn't worth bothering with
jss21382 is offline   Reply With Quote
Old 09-03-06, 06:58 AM   #23 (permalink)
kazuu_ka7's Avatar
Car 1: '91 HONDA LEGEND
Car 2: '95 LEGEND GS 6MT
iTrader Score: 9 reviews
JDM suskit for KA7,KA8 information.
AIMGAIN:front 12k,rear 8k, 60φ (previous model:70φ) fulltap
http://www.aimgain.net/products/dumper.html
Buddy Club:front 12k rear 6k,60φ fulltap
http://www.buddyclub.jp/product/damp...mper-sedan.pdf
I use AIMGAIN suskit,with SWIFT front 10k,rear 5k springs.
kazuu_ka7 is offline   Reply With Quote
Old 09-03-06, 08:30 AM   #24 (permalink)
misdeismo's Avatar
Wow, this is some good info. The kind only someone in Japan can dig up. I'm suprised BC makes coilovers for us. Never knew that. They are pretty big over at ckubrsx.com and H-T.com. thanks again for the info.
misdeismo is offline   Reply With Quote
Old 09-03-06, 10:15 AM   #25 (permalink)
How you like the zero FRONT toe?
No darting following road joints on the highway. To me feels like you took the parking brake off. Less tire wear too.
Rest of car is and shoud be adjusted to factory specs. Get those rusted bolts freed up.
Old 09-03-06, 03:13 PM   #26 (permalink)
swift's Avatar
car handles great switching lanes at 100+ now but i cant do rear camber yet because i may need that whole arm with bushing....have to see.
215whp+
Old 09-03-06, 10:59 PM   #27 (permalink)
these any good?? http://cgi.ebay.com/ebaymotors/GROUN...spagenameZWDVW
pro_foundac91 is offline   Reply With Quote
Old 09-05-06, 03:37 AM   #28 (permalink)
.The.Laos.Guy.
Super Soccer Champion
noudles's Avatar
Car 1: 1993 Acura Legend
Send a message via AIM to noudles Send a message via Yahoo to noudles
this is great and very useful information cut down my searching a whole lot
Thanks Swift
Legends of North Carolina
1993 Acura Legend L [SOLD]
2002 Lexus IS 300 [current driver]
noudles is offline   Reply With Quote
Old 09-05-06, 11:07 AM   #29 (permalink)
Old 09-05-06, 09:43 PM   #30 (permalink)
yea its Ground control, check the first page for more info on this on this product
WTB: Suspension (Struts & Springs) for Acura Legend L 1991 PoweredbyMe91 OEM Parts 5 10-03-06 06:11 PM
For Sale-OEM Springs Struts and Shocks rkcnb OEM Parts 0 09-22-03 09:54 PM
Old shocks & struts & springs problem? chez1701 Second Generation Legend (1991-1995) 1 06-12-03 09:02 AM
Old shocks & struts & springs problem? chez1701 Second Generation Legend (1991-1995) 0 06-12-03 08:08 AM
my rear suspension is sagging a tiny bit! is it due to weak springs or shocks? 91LegendCoupe Second Generation Legend (1991-1995) 34 09-03-02 11:07 PM
