Energy Suspension bumpstop question. - The Acura Legend & Acura RL Forum
Old 05-24-06, 11:10 AM   #1 (permalink)
Hello
I found these bumpstops in energysuspension.com
Can anyone advise me if these (9.9135, 9.9143) can be good OEM bumpstop alternatives?
Also, can these bumpstops be used with aftermarket suspension such as Koni Suspension Kit or KYB etc ?
I found that many are using 9.8107 for their lowering suspensions but I want to have a little more damping & height......
or any other options???
Thank you in advance.
LV_legend is offline   Reply With Quote
Old 05-24-06, 11:14 AM   #2 (permalink)
Blackend Motorsports
3 Wheel Slot Machine Champion
Blackend's Avatar
Car 1: Blackend Motorsports
Car 2: 1995 LS Coupe
iTrader Score: 23 reviews
I think hotlavaflow is using 9.6110 on his, and I will probably switch to those next time I mess with my suspension. I think I've already blown another 9.8107 on the drivers front...
Blackend is offline   Reply With Quote
Old 05-24-06, 11:17 AM   #3 (permalink)
swift's Avatar
Car 1: 92' C35 KA8 5spd
Car 2: 92' Ka8 5spd turbo
^^ i don't even want to know how.
215whp+
Old 05-24-06, 11:18 AM   #4 (permalink)
Blackend's Avatar
Practice for the National Meet!
Old 05-24-06, 12:18 PM   #5 (permalink)
iTrader Score: 24 reviews
hmm, maybe these energy bumps are pos, since i bottom my shocks every now and again (ask swift on my cornerning and such) and i'm using cut stock bumps and still ok
Old 05-24-06, 12:21 PM   #6 (permalink)
Blackend's Avatar
I think the ones I was using were not meant for this application. They're actually listed as shock eye bushings, and probably not engineered for the heavy loads from the top and bottom. The other part number I mentioned above should work much better since it is actually a bump stop.
Old 05-24-06, 12:24 PM   #7 (permalink)
yeah, thats exactly what i was just looking at on the energy website.
Old 05-24-06, 01:28 PM   #8 (permalink)
'hood Garage
Arcanoid Champion, Crab Ball Champion, Hail Mary Champion, Indian Shikar Champion, Jungle Monkey Champion
hotlavaflow's Avatar
Car 2: KA24DE-T S13
You got it. When you compare the difference between the stock bump and the ES bump (in your hand) you'll see.
BTW
Get the BLACK Energy Suspension bump stops. The black stops are self lubricating, the reds are not. I got all 4 for $18 shipped.
Sept'10 Reconstruction begins
hotlavaflow is offline   Reply With Quote
Old 05-24-06, 02:40 PM   #9 (permalink)
How about 9.9135 or 9.9143 that I asked about?
Are those totally wrong part to consider? to me it looked very similar to our G2OEM bump stops.
So our choice is only black 9.6110???
Old 05-24-06, 03:05 PM   #10 (permalink)
Blackend's Avatar
I don't think either of those two are meant to work with a strut. They both say "Designed to accept 3/8" dia. socket head bolt" so that seems like they attach to something, not go over the strut shaft. I would stick with 9.6110 just to be safe if you're lowered. If you're at OEM height, just get some OEM replacements.
Old 05-26-06, 04:30 PM   #11 (permalink)
Thanks you!
By the way, do you think I can use this 9.6110 bumpstop with "Koni+OEM spring" set up?
Old 05-26-06, 04:46 PM   #12 (permalink)
'hood Garage
Car 2: KA24DE-T S13
Thanks you!
They fit on my Koni's with no problem. Spring or coilover doesn't matter.
Old 06-09-06, 08:45 PM   #13 (permalink)
Ok! then anyone can recommend any internet vendor for Energy Suspension part?
Thank you
Old 06-10-06, 12:15 AM   #14 (permalink)
'hood Garage
Car 2: KA24DE-T S13
Just get them from this guy.
http://cgi.ebay.com/ebaymotors/Unive...QQcmdZViewItem
Old 06-10-06, 07:00 PM   #15 (permalink)
Blackend's Avatar
Or Jegs.com
H&R/Koni Bumpstop Question...(space bar works) ATLfoKuS Second Generation Legend (1991-1995) 3 04-22-06 10:22 PM
Suspension question. Need some numberss and advice please. Bemtje Second Generation Legend (1991-1995) 10 09-29-05 04:42 PM
Aftermarket suspension parts question chr8808 Second Generation Legend (1991-1995) 1 12-28-04 02:40 AM
All NOPI 2004 Threads in here! sleeprlegendcp Meets 26 09-16-04 03:30 PM
Does Energy Suspension make a kit for G2s? Octane Second Generation Legend (1991-1995) 4 01-29-03 11:47 AM
